ToughButterCup Posted September 9 Posted September 9 It's getting expensive now - any ideas how to do so without smashing the stone? I need to fasten some fence baseplates through capping stone ( Indian 'stone flags' 50mm 600 by 600) So far I've used a 6mm SDS with hammer action - might as well have used a pick axe used it without hammer - I want to finish the job sometime this year splashed a bit of water on the slab - better but still iffy.... Ideas please .....
BotusBuild Posted September 9 Posted September 9 Diamond drill bit? https://www.screwfix.com/p/erbauer-hex-shank-diamond-tile-drill-bit-6mm-x-67mm/51908
mistake_not Posted September 9 Posted September 9 Core drills are often diamond tipped if you want to drill a big hole.
ToughButterCup Posted September 10 Author Posted September 10 Thanks folks, on my way to Screwy's as we speak
ToughButterCup Posted September 14 Author Posted September 14 18 hours ago, BotusBuild said: Did it work? Yes. I used one of those hollow diamond-tipped drills with wax in the internal 'hollow'. I dribbled splashes of water to help form a grinding paste - interesting to watch the water on and in the surrounding stone evaporate after a few moments - cue for another splash of water. I find myself increasingly using AI to solve little problems like this. Annoyingly, I also find that AI (Gemini in this case) just plain wrong. Hence the check-question to BH. Thanks everyone for your help. 1
ToughButterCup Posted 6 hours ago Author Posted 6 hours ago (edited) For the sake of completeness, I thought I'd list the 'issues' I came across while doing the drilling; Here's one - I used AI to see if I could find an answer to the problem ( remove the broken stone stub ) . The answers - tap, poke, fiddle didn't work. Since I don't have a pillar drill any more, this ( below ) is what I'm going to try next ( 48 holes yet to be drilled ) The aperture of this drill is a good bit bigger, and there's a slot for a screwdriver to wiggle broken bits of stone out of the core. The narrower one above has no slot. I'm thinking of using the type of core 'drill' that attaches to a grinder (threaded shank) rather than a drill chuck - because I will be able to exert more pressure. But I'll have less control perhaps (?) Anyone have any advice? Edited 6 hours ago by ToughButterCup
Onoff Posted 5 hours ago Posted 5 hours ago When using these... https://rockbottomnorthampton.co.uk/products/draper-tungsten-carbide-grit-hole-saw-20mm-34866? I first smear a dab of copper or aluminium anti seize on the thread of the drill arbour. I constantly spray water on the drill. Periodically I hold the core drill with a bfo pair of moles or an adjustable spanner across the flats of the slots and reverse the drill to remove. Then knock the accumulated, compacted crud out with a bit of stud or rod. Go again, repeat. 1
