Drilling through 50mm Indian stone : with anything larger than a toothpick
It's getting expensive now - any ideas how to do so without smashing the stone?
I need to fasten some fence baseplates  through capping stone ( Indian 'stone flags'  50mm 600 by 600)
So far I've
  • used a 6mm SDS with hammer action - might as well have used a pick axe
  • used it without hammer - I want to finish the job sometime this year
  • splashed a bit of water on the slab - better but still iffy....
Ideas please .....
18 hours ago, BotusBuild said:
Did it work?
Yes.
I used one of those hollow diamond-tipped drills with wax in the internal 'hollow'. I dribbled splashes of water to help form a grinding paste - interesting to watch the water on and in the surrounding stone evaporate after a few moments - cue for another splash of water.
I find myself increasingly using AI to solve little problems like this. Annoyingly, I also find that AI (Gemini in this case) just plain wrong. Hence the check-question to BH.
Thanks everyone for your help.
For the sake of completeness, I thought I'd list the 'issues' I came across while doing the drilling;
Here's one -
I used AI to see if I could find an answer to the problem ( remove the broken stone stub ) . The answers - tap, poke, fiddle didn't work. Since I don't have a pillar drill any more, this ( below ) is what I'm going to try next ( 48 holes yet  to be drilled )
The aperture of this drill is a good bit bigger, and there's a slot for a screwdriver to wiggle  broken bits of stone out of the core. The narrower one above has no slot.
I'm thinking of using the type of core 'drill' that attaches to a grinder (threaded shank)  rather than a drill chuck - because I will be able to exert more pressure. But I'll have less control perhaps (?)
Anyone have any advice?
Edited by ToughButterCup
When using these...
https://rockbottomnorthampton.co.uk/products/draper-tungsten-carbide-grit-hole-saw-20mm-34866?
I first smear a dab of copper or aluminium anti seize on the thread of the drill arbour.
I constantly spray water on the drill. Periodically I hold the core drill with a bfo pair of moles or an adjustable spanner across the flats of the slots and reverse the drill to remove. Then knock the accumulated, compacted crud out with a bit of stud or rod. Go again, repeat.
