flanagaj Posted 9 hours ago Posted 9 hours ago Not sure if it's acceptable to do this, but our new builders have laid the blocks onto the Radon DPC with no mortar below the DPC and only mortar above the DPC. I did question this and they said it's fine. I even raised it with BCO and he said it was ok. Doesn't sound right to me, but I wonder if anyone has any experience of this approach. This xxxxxxx Radon membrane is the bane of my life and our neighbours said there isn't Radon here (BGS maps show 3%) The thought of having to demolish another bricklayers work is going to send me over the edge.
MikeGrahamT21 Posted 9 hours ago Posted 9 hours ago Whether right or wrong, I’ve had 4 extensions done on my bungalow and none of them have mortar below the DPC, only above, and haven’t had any problems in the last near on 20 years. I have read people mortaring under the DPC but not sure what it brings really, plastic is never going to adhere to mortar, not strongly anyway, and the weight of what’s above will keep it where it should be
flanagaj Posted 9 hours ago Author Posted 9 hours ago 29 minutes ago, MikeGrahamT21 said: Whether right or wrong, I’ve had 4 extensions done on my bungalow and none of them have mortar below the DPC, only above, and haven’t had any problems in the last near on 20 years. I have read people mortaring under the DPC but not sure what it brings really, plastic is never going to adhere to mortar, not strongly anyway, and the weight of what’s above will keep it where it should be I can see why they don't put mortar underneath. You have a continuous sheet of DPC which is 500mm wide on the horizontal and then it rises 225mm on the vertical before spanning the outer leaf. Plus it's all taped to the corners, so how you would physically lift it up to put mortar underneath it is beyond me.
Mr Punter Posted 7 hours ago Posted 7 hours ago Please shut up about radon. It is low where you are. More chance of being run over by a milk float. 1
