Spinny Posted 10 hours ago Posted 10 hours ago Kitchen fitter has done the plinths and completely unexpectedly and never previously communicated, has routed the bottom edge of all the plinths (which had finished board edges anyway) and inserted a sealing strip - see photos. On asking what this is I have been told it is a water seal to stop liquid running under the plinth. Really not sure what I think of this. Don't like it aesthetically, will it get dirty over time ?, is it really necessary at all ?, is it just a crafty way of dealing with uneven floors ? We lived in our old kitchen (fitted by previous owner in late 1980's) for 30 years and never had a problem with the plinths which didn't have anything like this ? Is this normal now ? Can I, should I reject it ? Anyone else got this type of thing ?
-rick- Posted 9 hours ago Posted 9 hours ago My (now old) kitchen has this. Believe they are fairly common. I didn't even know they were there until I had to remove the plinth. Can you see them when standing up? It may be your old kitchen was made with more solid wood. With Particle Board you really want to stop any dampness as it will swell up like a balloon at the slightest provocation.
Mr Punter Posted 9 hours ago Posted 9 hours ago I have seen the plinth seals that wrap around the bottom edge. They are friction fit and could be replaced. They are probably a better solution as you don't have to rout a groove.
Gone West Posted 2 hours ago Posted 2 hours ago 7 hours ago, Spinny said: Is this normal now When we fitted our kitchen in 2016, the plinths came with sealing strips to fit to the bottom of the plinths.
Spinny Posted 1 hour ago Author Posted 1 hour ago 7 hours ago, -rick- said: Can you see them when standing up? Yes, once you are standing about 1.5m or further away you can see them. And of course more so if sitting. Thus they appear to be colour coded to match the plinth colour. Dirt is presumably going to collect in the gap they leave, and presumably they will get dirty in time and need replacing or removing to wash. Given that walls are finished with skirting and no further 'protection' it seems a very questionable practice. Why not just use something moisture resistant in the first place to make the plinths. I would suspect it is at least as much about saving fitting costs by avoiding any scribing into uneven floors ? Odd that any panels in contact with the floor have sealed panel ends and are not treated in the same way. This system is cutting off sealed plinth bottom edge to insert the protective strip. How common is this practice ? AI tells me... Quote No, high-end or bespoke luxury kitchens typically do not use standard plastic or PVC plinth protection strips. Why High-End Kitchens Skip Plastic Strips Aesthetics: Plastic or rubber push-on sealing strips disrupt the clean, minimalist lines expected in luxury design. High-end kitchens prioritize seamless, uninterrupted materials down to the floor. Material Quality: Luxury brands use solid wood, moisture-resistant MR-MDF, lacquered finishes, or metal plinths (like brushed stainless steel or brass) that are inherently sealed or treated against moisture during manufacturing. Precision Fitting: High-end kitchens are professionally scribed and fitted precisely to the floor level. Instead of relying on a flexible rubber lip to hide gaps or block water, premium installations rely on tight tolerances and silicone sealing where necessary. So another little something deliberately omitted from the sales pitch. I will be taking another look in the showroom as I don't remember seeing any on the show kitchens.
G and J Posted 36 minutes ago Posted 36 minutes ago 1 hour ago, Spinny said: look in the showroom Just out of interest in this an independent or a "chain"
