saveasteading Posted yesterday at 12:31 Posted yesterday at 12:31 Just now, Oz07 said: can the architect just use robust details or whatever the standard rules are? Yes. The average house with cross-walls is sufficiently braced. In big open spaces this changes. You can see in warehouses that the wind bracing is provided by diagonal bars or angles on the outside walls which take the wind load out in simple tension, plus some compression struts at the top. In a gale it is sometimes possible to see the bars tensing up. In an extreme wind I've seen them 'snap' tight and make a noise. There will be similar crossed rods in the roof to transfer loads to the walls then down to ground. But if there is no space for these bars because of movement paths or glazing etc (eg car showroom), then a post is used. Also in an enormous shed with intermediate columns and no walls. It can be a post on its own, or more usually adapted on the sides of an existing column, making it into a Maltese cross shape. The forces at the ground can be enormous so it nearly always needs a very big concrete footing (I think we once put about 6m3 of concrete in the one base.) They are expensive so sometimes worth 'designing out' with client approval. So a house with very big rooms or large areas of glazing might need individual posts or 'goalposts. But these are seldom considered at preliminary stage where space and appearance come first. 1
flanagaj Posted yesterday at 13:55 Author Posted yesterday at 13:55 So cut a long story short, I got back in touch with the original SE on this matter. Their response. Seems the current SE is over engineering. "on the basis of the plans in our structural calcs we do not consider that wind posts are required provided the ground floor constructed of blocks and timber stud walls are lined with plywood/OSB and tied to the masonry walls." 1
saveasteading Posted 2 hours ago Posted 2 hours ago 18 hours ago, saveasteading said: End of story. It's only fair to say that we don't know the relative skills or responsibilities of these consultants, and that the second one was not responsible for the main design, and may have had an equally acceptable proposal if they had been. There was not zero cost in stiffening the building with ply or osb, and a wind post might have been a good option IF incorporated from the outset. 1
