September 1Sep 1 Hi all, We've had our old white soffits and fascias replaced this week with UPVC Oak. Our old white soffits were 550mm and were vented (25mm continuous cut outs toward the outer edge). The roofer doing the work has told me they just don't make them that deep in UPVC Oak, so has told me we'll go with a Hollow board soffit instead. Visually I think it looks fine, but obviously not vented. I enquired with the roofer about sufficient ventilation, they said they'd add fascia vent strips as an equivalent ventilation method. However now installed I can see the membrane droops quite low and could be blocking those strips.... again i've enquired, roofer said not a problem. But figured better to get a second opinion on here before the scaffolding all comes down. what do you think? Cheers Ged
September 2Sep 2 Pictures? There is an alternative, I think called an over fascia vent. This has the front vent holes facing downwards so less likely to be troubled by a membrane hanging down the front.
September 2Sep 2 Author thanks @ProDave will take some snaps when i'm home, it has those over fascia vents on there, but the bitumen is drooped over them and hanging into the gutter. That's my concern that the bitumen is essentially obstructing the air going into those vents.
September 2Sep 2 With the over fascia vents the airflow comes up from underneath. The plastic eaves membrane support trays are better than bitumen but either should be fine.
September 2Sep 2 8 minutes ago, Mr Punter said: plastic eaves membrane support trays I'd ask for these to be installed while they're doing the work - they're cheap, will support the felt better and won't degrade in the sunlight.
September 3Sep 3 Author On 02/09/2026 at 13:03, torre said: I'd ask for these to be installed while they're doing the work - they're cheap, will support the felt better and won't degrade in the sunlight. I'll ask for the eaves guards to go in before the scafff comes down, good call. thanks.
September 3Sep 3 Author On 02/09/2026 at 12:51, Mr Punter said: With the over fascia vents the airflow comes up from underneath. The plastic eaves membrane support trays are better than bitumen but either should be fine. Interesting, lifting up the felt on ours the vents appear to be facing outward away from the brick work, rather than downward.... maybe they'ved used a different type on ours, or installed them back to front? Is that a problem? Photos below.
