Rain noise on Velux type windows - is it better with 3G?
Hi, I'm just at the stage of designing my house and I have mentally discounted Velux type windows as my experience with them in the past has been that the rain noise wakes me up and causes sleepless nights.  However, I'm just wondering if new tech ie triple glazing etc has made this any better?  From a quick Google I can see that in theory 3G and acoustic glass should make a difference but I wondered if anyone has some real-world experience of this?
We have 3 passive approved triple glazed  electric Velux windows in a vaulted kitchen ceiling.
Noise is not an issue for me or my wife. None in bedroom though, a small one in the hall just outside bedroom, again noise not an issue.
Definitely much much better than 2G, and they also do one with thicker glass on the outer pane which lessens it even more, designed primarily for use in bedrooms, so may be worth looking at that unit
Yes it is. We went with the top of the range 3G ones for our bedroom (replacing 2G Veluxes) and now sleep through rain storms - most of the time.
Fantastic thank you. Can you remember the make and model by any chance? Cheers
You can further attenuate noise by installing integral, internal (Velux) blinds / curtains.
Every little helps.
GGU PK10 0070 94x160 cm manually operated white polyurethane VELUX window, with the 62 pane in the bedroom.
This has reminded me though, we had one fitted in another room with a 68 pane (significantly cheaper) and this cuts down rain noise pretty well - but not speech noise from outside. As its lighter the hinges work better, my wife struggles to shut the ones in our bedroom.
