August 11Aug 11 Hi all, Have found this forum helpful over the last year while completing my self build in Ireland. I am wondering if anyone has advice on the best way to seal Hollowcore ends before pouring the next lift of ICF walls. Currently weighing up a sand and cement mix vs a rockwool plug (both pushed 100mm inside the core). Curious whether there are other better suited options I haven't considered. Thanks Ross
August 12Aug 12 I don't recall ever doing it. But your way seems sensible. Push a plug of rockwool to give a stop then a sharp sand mix as facing.
August 12Aug 12 Author Thanks for the responses. The external walls are being built up with ICF. The way the standard interface works, is that the hollower bears 80mm onto the concrete core of the ICF wall below. We then build up ICF walls from this level for the next wall pour. The main objective is to stop the concrete from the ICF flowing freely and uncontrolled into the cores. If there is no 'stop' there, there is nothing to prevent it. Airtightness in my understanding shouldn't be effected in reality, as either way the cores will be sealed by the external wall pour. It's more to do with managing the flow of concrete into the core.
August 12Aug 12 22 hours ago, RossH said: Have found this forum helpful over the last year while completing my self build in Ireland. Hope you are enjoying BH, we have lots of fun here. Remember there is no such thing as a stupid question! 16 minutes ago, RossH said: The external walls are being built up with ICF. The way the standard interface works, is that the hollower bears 80mm onto the concrete core of the ICF wall below. We then build up ICF walls from this level for the next wall pour. As an SE I often look at bearing lengths for say Hollo core slabs. Generally on masonry standard is 100mm, on concrete (ICF) min 75mm, I then deduce your SE is taking into account construction tolerance, hence the 80mm. That's a good sign! The bearing length is vitally important as the floor slabs often act as diaphragms that tie the house together. But now we need to look at your pour sequence. Normally we would cast the first lift up to underside of Hollo slab, set the slabs, then carry on. A standard ICF domestic core is 150mm of concrete, sometimes a bit more. Now if you have a 80mm rest on your Hollo core that technically leaves 150 - 80 = 70mm of concrete before the outside skin of insulation, and that bit is going to be very hard to compact properly as it's going to be at the bottom of the next shutter lift. Have you considered extending the Hollo core slab rest to the full thickness of the concrete core so it sits flush with the outside edge of the concrete core? Then you'll have much better tying and can foam up the Hollo cores to your hearts content as they will be easily accessible? If you really want air tightness you can seal off any gaps within the floor depth as the end of the Hollo slabs will be flush with the inside face of the outside insulating layer of ICF,, that's a tongue twister! I may have missed something here. You SE may have introduced some extra floor to floor tying rebar, hence the reason for the 80mm bearing? Can you post the details you have? To finish, good question and hope you enjoy BH, folk chipping in, but also remember that folk that come after you will learn from your posts and experience. For me, it's also my day job, I also learn from your innovation, so thanks.
August 14Aug 14 A few insights from my ICF build. The planks can only partially bear as you have vertical rebar coming up from the wall below that needs to tie into the next wall. You don't need to seal up the end of the slabs - a combination of the small diameter of the holes, interference from rebar, and by not working the concrete at that point (poker will vibrate the concrete at the bottom of the formwork), it simply won't flow in more than a short lenght if the consistency of the concrete is correct. You won't have an issue unless you are using an overly low slump / high flowing mix. Also, you normally need to bend over a certain number of the vertical bars and break into the planks. Then get grouted in, in order to tie the floor to the wall.
August 15Aug 15 11 hours ago, Conor said: A few insights from my ICF build. Always helpful 11 hours ago, Conor said: The planks can only partially bear as you have vertical rebar coming up from the wall below that needs to tie into the next wall. Thus the rebar has to have adequate cover and be surrounded by well compacted concrete. This concrete is at the start of the next lift, well down the shutter. Very difficult to achieve. The only reason for continuous rebar between floors is if you have particular fire or disproportionate collapse requirements. Less onerous on the standard ICF build. In fact.. if you add rebar into the ends of Hollocore slabs and tie that into the external walls then you start to create a moment / partial stiffness connection. You then introduce an extra bending force into the walls, thus you need to design for that, it potentially causes problems with concrete core thickness. 11 hours ago, Conor said: You won't have an issue unless you are using an overly low slump / high flowing mix. Disagree, a lot, not really applicable to self build when using ICF, you are mixing up platform and core lifting with ICF which is a different animal. 12 hours ago, Conor said: Also, you normally need to bend over a certain number of the vertical bars and break into the planks. Then get grouted in, in order to tie the floor to the wall. If you give your Hollocore slabs full bearing on the ICF core (say 150mm) then this often satisfies the tying requirement on a low rise buildings, like self builds. My advice stands. Recognise that on your second ICF lift it's going to be hard (impossible actually) to get adequate concrete compaction at first floor level when you have to get the poker all the way down the base of core if there is more rebar congestion. Keep it simple, extend the Hollocore out to the external face of the core. Always check with you SE in case there are funny point loads or lateral bracing requirements. My advice is general, but intended to be practical in the first instance.
