July 31Jul 31 When joining kitchen units together, is there a standard practice for placement of connectors. I'll be putting one connector behind the back panel... Ta
July 31Jul 31 1 hour ago, crispy_wafer said: When joining kitchen units together, is there a standard practice for placement of connectors. I'll be putting one connector behind the back panel... Ta Any decent carpenter / kitchen installer will take the hinges off, clamp the units together exactly aligned, and then screw through with 30mm countersunk wood-screws (not the thru-connectors) so the hinges hide the screws. Note: for 15mm carcasses use 25mm screws, and only use 30mm for 18mm.
July 31Jul 31 Author 11 minutes ago, Nickfromwales said: Any decent carpenter / kitchen installer will take the hinges off, clamp the units together exactly aligned, and then screw through with 30mm countersunk wood-screws (not the thru-connectors) so the hinges hide the screws. Cheers, I'll have a go at that...
July 31Jul 31 Easyfix Furniture Inter Screws M4 x 33-42mm 10 Pack - Screwfix you can use these too if for some reason you don't want the screws behind the hinges
July 31Jul 31 Don’t put a fixing behind the back panel, you will never know it’s there and will never be able to remove a cabinet if you need to.
July 31Jul 31 3 hours ago, Nickfromwales said: Any decent carpenter / kitchen installer will take the hinges off, clamp the units together exactly aligned, and then screw through with 30mm countersunk wood-screws (not the thru-connectors) so the hinges hide the screws. Note: for 15mm carcasses use 25mm screws, and only use 30mm for 18mm. That is a lovely tip and one I would never have thought of - Thanks for sharing New Kitchen being delivered in Oct so very useful and timely
July 31Jul 31 Like Nick says, is what I did. Those bolt from each side things that came with DIY kitchens I simply didn't use, just screws behind the hinges or if I couldn't do that I just counter sunk and used the colour coded stickers.
July 31Jul 31 42 minutes ago, Super_Paulie said: Like Nick says, is what I did. Those bolt from each side things that came with DIY kitchens I simply didn't use, just screws behind the hinges or if I couldn't do that I just counter sunk and used the colour coded stickers. The wax sticks are good too.
