2 hours ago, Reggie1 said:
Should I use one of these
How good are you at keeping records?
Could easily make your own
Edited by SteamyTea
I wouldn't. It is a well made , fit for purpose, and precise thing, and I don't think expensive.
The only issue would be if the crack has completed its shrinking and starts to close again when the rains come. I think it would just shatter then, but still a point proven.
Maybe glue one side only and take measurements and photos to account for this happier possibility.
I will buy some and place them on all the cracks ive pictured, but i was wondering if a structural engineer would take offence, as someone mentioned about the document ive produced. Also should i apply them and get an engineer in say October to give some usefull info, as the weather will have changed by then?
what's the approach i should take, structural engineer now, or apply these and wait till october?
These cracks may have happened when we had that really bad snow and there was a lot of thick snow on the roof. I think the pointing is in need of re doing so the walls probably could be stronger.
As it happens I'm an engineer just not a structural one, so I need an approach to take, as I'm not too sure on how to approach this.
Suggest just call up, describe the problem in round terms, send them a few pics and ask them to take a look and give an opinion. Maybe an informal opinion and recommendation rather than a report. They may charge for their time but it’s probably money well spent. They’ll like dealing with you if they don’t have to explain the basic laws of physics 😀.
Edited by Alan Ambrose
If you think your report will be credible then fit them and take readings fortnightly, listing on a spreadsheet. Summarise  the weather over the period.
Take photos too. Lots .They can always be deleted.
But if you are going to engage an SE then why not now? They won't mind you doing your own thing in the interim.
But just phone one, maybe two and don't send that inquisition form.
