Sunday at 08:432 days Mind you, for a 60sqm bedroom wing, I'm looking at about £1.2k for the styrofloor thing, or as little as £800 if I buy xps and chipboard separately... Appreciate this is not comparable to 10cm PIR, but will probably feel better than 2mm LVT glued to concrete. I imagine at the rate we're going, this time next year we'll be paying £800 for a tank of diesel.Biggest issue is the 4-6cm reduction in door height. Edited Sunday at 08:442 days by tetris
Sunday at 08:531 day 18 minutes ago, tetris said:carpets in a corridor won't survive a fortnight.You do have to pay more for hard-wearing, which will last years.If you don't mind the utility look then carpet tiles . In office quality they will last you out, and allow kids' wheely toys, and for any accidents, plasticine or damage, can be taken outside to clean. I have some salvaged from an office after 7 years of heavy use, used in a corridor, gym, workshop area. It is on an uninsulated concrete slab. I put an underlay of 10mm down first. The theoretical insulation (by U value) is low but much better than nothing, and the effect on feet comfort and warmth is significant.
Sunday at 09:501 day Not sure this really makes sense in your situation but throwing it out there just in case:If you are thinking about putting thin polystyrene in the floor and boarding over it, then think about whether you could use one of the thin UFH products (pregrooved polystyrene that acts as a template for the pipes). That might solve your radiator issues (and generally UFH will be cheaper than buying a load of vertical rads).Important note is that the insulation layer is not thick enough for an external floor (would be very expensive to run), but if all you have below the floor is another habitable room then the small amount of insulation might not be a big deal. It would certainly solve the cold feet issue.The floor still won't be as good as a screeded ufh setup but everything is a compromise.The biggest issue in your case @tetris is likely that you want to do this quickly while living in the place and doing that with the floor might be tricky and certainly requires careful thought.
Sunday at 10:051 day Thank you - it's a bungalow, and I've read (on this forum if memory serves me right) that unless you have 10cm PIR below UFH, all you're doing is heating up the floor void.
Sunday at 10:071 day Just now, tetris said:Thank you - it's a bungalow, and I've read (on this forum if memory serves me right) that unless you have 10cm PIR below UFH, all you're doing is heating up the floor void.Doh! You are correct. Sorry I think you mentioned that in a previous post. I was thinking this was a first floor. Edited Sunday at 10:071 day by -rick-
Sunday at 12:581 day I would spend time making sure your floor is sealed to stop drafts that may be there. Then spend you money a good thermal underlay and a wool carpet. Do the same in bedrooms and corridor.A very quick search brought up thishttps://www.carpet-underlay-shop.co.uk/collections/thermal-insulation-underlay/products/56oz-heat-insulation-wool-carpet-underlay15mm thick, add a good carpet job done.Sealing the floor to make sure it's airtight would be my priority.Another layer could be thermal tile backer boards, glued direct to floor and then underlay and carpet.
Sunday at 13:191 day Thanks. SWMBO sets the cleanliness standards around here, as she's the one who does the cleaning. Her view is that carpets become very dirty to the point of needing replaced the moment they leave the manufacturing facility 😁.Carpets in bedrooms might just be the way to go in our case, but no carpet is ever going into the corridor (and I have to agree - the amount of dirt that my kids will get into it within the first fortnight will make me want to chuck it out). Even for bedrooms the carpets would not be our first option. Small kids get sick all the time. When they get sick, they puke. If that gets into the carpet, even a weekend with a carpet cleaner is not going to get the smell out of it.Here's a thought: Would 25mm XPS sheeting take care of slightly uneven flooring (within +/-2mm perhaps?), so I can just put 18mm chipboard on top and that's the top floor ready for clicking? Sounds like a huge time saver if that's the case.Current carpet + underlay thickness in rooms is 15mm. If I raise the floor by 50mm, less 15 from carpet removal, less another 15 from raising the doors, I'm only getting a net floor height increase of 20mm. If that means fast & easy floor installation + some insulation benefits, this is starting to look quite attractive.
Sunday at 13:351 day In that case go straight tile backer, even a couple of layers glued down and tiles. Why bother with the chipboard at all
16 hours ago16 hr chipboard to spread the load of the click flooring?Tile backers description reads like they might be OK but has anyone here used them for flooring?
13 hours ago13 hr 2 hours ago, tetris said:has anyone here used them for flooring?yes. under a heating mat under tiles. and it's no bother. they are a good compromise of insulation, strength and general robustness.
11 hours ago11 hr If I understand correctly, it's just XPS with a thin hard layer on top of it? I'll be floating click laminate or LVT, rather than gluing tiles to it, and none of these are officially compatible with click flooring because it spreads the load differently from glued-on ceramic tiles?And does the XPS act as a DPM in itself?Apologies, I might be asking very daft things here.
1 hour ago1 hr 10 hours ago, tetris said:might be asking very daft things here.Questions are seldom daft.Keep asking.Marmox etc are not eps and are robust. I've seen an eps equivalent and it isn't, but might be OK under flooring.I'd probably paint a dpm first.
34 minutes ago34 min Well, I started with "Insulating suspended concrete" and ended up with "cheap & easy way to install click flooring on uneven surface while also getting marginal insulation benefits" 😬 I think this is quite far down the daft spectrum tbh.Thanks for the MArmox heads up - seen the name mentioned while lurking around this forum, but didn't know what it was.Marmox offer "Sound Multiboard" that's specifically stated as suitable for laying laminate on top, but it comes in 12mm thickness and is about £20 per sq m. Might be a solution for the corridor if I need to raise it just a bit to match bedrooms.For regular multiboard the kpa is impressive (400kpa) - 3x higher than floor-rated PIR and 2x higher than regular XPS, but again, they specifically state that it is not designed to resist point pressure.I couldn't find any mention of people successfully laying click on top though and manufacturer does not list it as designed for click flooring. The former is particularly concerning.So, seal all gaps around the perimeter; paint DPM, (check floor unevenness is within 3 over 3m), lay marmox foam-down, lay laminate on top? Edited 27 minutes ago27 min by tetris
Just now1 min You take out level changes and uneven areas with self levelling compound. Liquid dpm. Then an even layer of the insulation across the whole floor area.
