I have been talking to 2 solicitors about my Leasehold to Freehold enfranchisement. Already rejected a couple of others due to geography or other things.
One has quoted £1600 and the other about £9500. I am not the sort of person that would usually gravitate towards the cheaper option in any scenario. But the difference here is huge.
For any solicitors that might be reading this...
#1 Is this gulf common?
# Do solicitors respond well to a haggle
# If the figure is based on a formula that is open to the customer how are the numbers derived.
# I thought there was another question. It'll come back to me
13 hours ago, Mr Punter said:
Are the other leaseholders on board?
There are no other leaseholders.
The land on which i built our house has been an Orchard for at least the past 125 years. It is a 'lost leaseholder'  status piece of land.
The status of the land is not at issue. The massive difference in Fee's is.
I'm surprised you haven't had more contributions on this thread. There have been in the past some people on here who might be able to answer but I guess they aren't around ATM.
Not a lawyer but I think in general the bigger, better reputation, firms charge more. If they are a bigger firm they can handle bigger cases and therefore people with bigger wallets and thus don't want to lower their fees for smaller stuff.
Going to a smaller firm (even one man band) might not be a detriment if you are dealing with someone who has fairly specialised knowledge in your area of concern. But if they are more of a generalist and you need a specialist then you would be at a disadvantage.
So question is does this describe the difference between the firms? Have you asked the more expensive firm why their price is so much higher? (Not haggling, but asking them to justify the price). In terms of the £1600, that sounds about as low as is reasonable given this job is maybe a little unusual.
Doubt the above is anything you haven't already thought about but maybe it triggers some more useful conversation?
Solicitors are a whole new playing field. £500 for a local firm to write a simple letter seems to be par.
in principle, quotes for work like this are based on no of hours expected x (outrageous) hourly rate. Things that bump the rate significantly are (a) specialist work that not many lawyers understand and therefore can do, (b) critical advice on high ticket items, (c) practice brand name recognition. An easy ask is ‘what’s the process’ and ‘how many hours do you think it would take’ (+ ‘what’s your billing rate’). They will be very open about their billing rate. Also, what skills they have.
It’s unusual to just get a fixed number unless that’s what you asked for or the work is so standard (e.g. conveyancing) everyone knows how long it usually takes. Maybe the £9.5K number means ‘we’ve never done this before and we’re not particularly interested in finding out how unless you make us a stupid offer’.
We’ve had an awful lot of success over the years by building relationships by using the same peeps repeatedly and once we feel we can trust said dudes we get a feel from them of the scale of the job but then go with day/hourly rates.
We’ve found that if one always insists on fixed priced arrangements unless as mentioned above, it’s bog standard stuff then to be safe the person quoting needs to allow for the possible googlies awaiting them.
If you look at it from the other end of the contract they may well think ‘I don’t know you or how much of a pain in the bum/slow payer you are so I’m gonna build in contingency’. Kerr-ching.
Might be worth an hourly rate discussion with both.   I’d certainly investigate further as the £1.6k sounds a bit too good to be true.  Oh, and might be worth ensuring that both quotes include necessary disbursements.
 It is not just a fixed number, the expected court hours are included X rate/hr. I just didn't include this earlier. 30 court hours by the way.
The expensive guy has done most of the other houses in the village, the entire village exists under the same lost lease holder. Most have gone through this process over the years. Therefore it is not new to him or complicated. And, very probably will not have any unexpected problems.
The cheaper guy is currently representing my neighbour through the same procedure.
I guess you mean lost freeholder?
I wonder if it's a case of first time there was a lot of risk priced in and since then, they get a referral and kept the price the same?
Can you wait and see how your neighbour gets on with the cheaper option?
