Marvin Posted July 3 Posted July 3 I want to add some more PV panels to my system. The ones I have all face south with no shade The panels I want to add will face east and west. What sort of panels can if fit to the two separate rings I already have without losing power from the existing ones?
JohnMo Posted July 3 Posted July 3 (edited) You just put the new one a different inverter or if your existing inverter has spare MPPT do that, then they can be anything you want. East and west can go on one MPPT (but need to be same panel design, same number of panels and same angle) or 2x MPPT if you want. Do not connect on the same MPPT as your existing South facing, as new panels are very unlikely to match your old ones Edited July 3 by JohnMo 1
Marvin Posted July 3 Author Posted July 3 Hi @JohnMo 6 minutes ago, JohnMo said: You just put the new one a different inverter or if your existing inverter has spare MPPT do that, then they can be anything you want. East and west can go on one MPPT (but need to be same panel design, same number of panels and same angle) or 2x MPPT if you want. Do not connect on the same MPPT as your existing South facing, as new panels are very unlikely to match your old ones I will come back to this if you don't mind. I need to change my inverter to one that will allow my system to charge batteries, supply to the mains, and go off grid. Is there such a thing?
JohnMo Posted July 3 Posted July 3 Hybrid inverter. But they are generally equipped to do limited off grid output. Some makes will do a gateway which will allow the full inverter output in a power cut. Or AC coupled battery with gateway will will allow normal string inverters to work in a power cut. Depends if you already have your battery? All the above depends on what you mean by off grid?
MikeGrahamT21 Posted July 3 Posted July 3 11 minutes ago, Marvin said: Hi @JohnMo I will come back to this if you don't mind. I need to change my inverter to one that will allow my system to charge batteries, supply to the mains, and go off grid. Is there such a thing? I believe Tesla powerwalls do this, but it’s a hard thing to achieve in the UK as in the event of a power failure, any generation or potential export should turn off or island, and for that reason most don’t operate the whole fuseboard on backup, rather just a backup socket for emergency loads to be plugged into. Maybe someone else knows more about this, but mine certainly doesn’t as an AC coupled. Don’t agree with East and West connecting to same MPPT, my east and west panels are both active in differing amounts simultaneously, and in winter east does far better than west. Either use a separate inverter, or get a triple MPPT one to handle all 3 strings, these are widely available as normal and hybrid. A good question, do you get the feed in tariff? If you do then don’t go hybrid, as it will wipe out a lot of your income. 1
JohnMo Posted July 3 Posted July 3 2 minutes ago, MikeGrahamT21 said: Don’t agree with East and West connecting to same MPPT, my east and west panels are both active in differing amounts simultaneously, and in winter east does far better than west. I didn't until someone here pointed me towards design / install instructions that said you could, so researched further. And indead you can and the output per year is actually better than 2x MPPTs as they run longer at best efficiency point. But strings need to be identical, as in number of panels, mounting angle. 2
MikeGrahamT21 Posted July 3 Posted July 3 9 minutes ago, JohnMo said: I didn't until someone here pointed me towards design / install instructions that said you could, so researched further. And indead you can and the output per year is actually better than 2x MPPTs as they run longer at best efficiency point. But strings need to be identical, as in number of panels, mounting angle. wonder how that comes about? Just can’t imagine it from my own install. Have you done this and observed the output difference? 1
JohnMo Posted July 3 Posted July 3 (edited) 14 minutes ago, MikeGrahamT21 said: wonder how that comes about? Just can’t imagine it from my own install. Have you done this and observed the output difference? No, but others have. Here you go something to read se-ta-efficient-east-west-orientated-pv-systems-wi.pdf Edited July 3 by JohnMo 1 1
Dillsue Posted July 4 Posted July 4 Maybe Im missing something but the Fronious write up is comparing output of 2 E-W arrays each with different panels, mounted at differing inclinations and facing different directions?? Hard to see how you'd get a meaningful comparison of them wired to a single inverter VS 2 separate inverters??
MikeGrahamT21 Posted July 4 Posted July 4 17 hours ago, JohnMo said: No, but others have. Here you go something to read se-ta-efficient-east-west-orientated-pv-systems-wi.pdf 352.78 kB · 4 downloads Really interesting that, not what I expected. So essentially there are losses and the sunnier it is the greater they are, but even then it’s minimal and saves buying another inverter.
JohnMo Posted July 4 Posted July 4 49 minutes ago, Dillsue said: Maybe Im missing something but the Fronious write up is comparing output of 2 E-W arrays each with different panels, mounted at differing inclinations and facing different directions Think your missing something. One of the rules is the east and west face panels have to be matched. They are comparing essentially 4 systems. One thin film, to one inverter and also 2 inverters, same for Crystalline.
Dillsue Posted July 6 Posted July 6 Just re read it and understand how they've split the arrays....as you say. I'm not sure how valid that paper is with today's kit. The paper seems to be from 2013 when panels were a fraction of the wattage/current than they are today. For a single inverter/MPPT system they say the E/W arrays must be wired in parallel which will significantly increase the current over that of a single E or W array. Back in 2013 the combined current would still be quite low and likely manageable by a single inverter/MPPT. With modern panels the current is significantly higher than those from 2013. Put 2 modern arrays in parallel and you could go over a single inverter/MPPT limit?? With figures plucked off the Web you've got a max 15A DC input for a solis 5kw inverter and Longi 450watt panels with a max 11A output. Put 2 longi strings in parallel and I'd be pretty sure your going to exceed the inverters 15A input limit??
JohnMo Posted July 7 Posted July 7 8 hours ago, Dillsue said: Put 2 longi strings in parallel and I'd be pretty sure your going to exceed the inverters 15A input limit?? Very true. A 3x MPPT hybrid inverter may be a better solution. Assuming a DC battery. If AC coupled battery any 2x MPPT inverter in addition to the existing inverter would be fine. Just need to manage the export limit.
-rick- Posted Tuesday at 11:16 Posted Tuesday at 11:16 On 06/07/2026 at 21:59, Dillsue said: With figures plucked off the Web you've got a max 15A DC input for a solis 5kw inverter and Longi 450watt panels with a max 11A output. Put 2 longi strings in parallel and I'd be pretty sure your going to exceed the inverters 15A input limit?? There are two ratings on an MPPT for current. One is the maximum current it can usefully convert, the other is the max short circuit current. As long as your arrays in parallel stay below the max short circuit current then the effect of having more generation capacity on one MPPT than it can handle just limits the maximum energy you can generate. On an East/West (or North/South) array it's very unlikely both sides will be operating near maximum at the same time and for the few hours per year they do its not necessarily worth the cost of another MPPT. Solar panels are so cheap compared to everything else that it's often worth maxing them out to increase generation outside peak/during winter at the expense of not being able to use all generated energy in peak summer.
Dillsue Posted Wednesday at 12:55 Posted Wednesday at 12:55 On 14/07/2026 at 12:16, -rick- said: On an East/West (or North/South) array it's very unlikely both sides will be operating near maximum at the same time and for the few hours per year they do its not necessarily worth the cost of another MPPT. The 2 arrays don't have to be operating near maximum. With the figures I posted one array can be near max and the other at 50% for the inverter to start clipping output. I dont know the difference in price between a single and dual MPPT inverter but would guess its not much. Going for a dual input removes this issue entirely and would then avoid clipping for the life of the system
-rick- Posted Wednesday at 16:01 Posted Wednesday at 16:01 3 hours ago, Dillsue said: I dont know the difference in price between a single and dual MPPT inverter but would guess its not much. Going for a dual input removes this issue entirely and would then avoid clipping for the life of the system Bottom line is it comes down to money depending on the situation. But worth considering (again dependent on specific circumstances) if overpanelling may lead to longer run time/more energy generated in winter. ie. in low light, the panels acting together produce enough to overcome the inefficiencies/minimum input of a single mppt where as two separate strings on separate mppts never get above the threshold. I think this is much more likely in older installs with newer tech it not being a concern but worth bearing in mind.
