PSC88 Posted July 1 Posted July 1 Hi anyone with expertise with ecology stage valuations and draw downs? they don’t follow typical stages or give a clear indication of how much they will release at each stage only that they will release funds as the build progresses. i have a mortgage that will release up to 65% of the value at any one stage. i drew down the max 65% of my plot valuation to clear my previous residential mortgage (knock down and rebuild) and this left a small buffer to commence the build. i have enough funds to get to foundation and block and beam using the buffer and personal savings. im planning on then getting them out to value and release funds. The question is will they release enough to get to the next stage! And what stage would I then be calling them out again? my build is quite heavy in the earlier stages up to wind and watertight and would be great if I could budget effectively .
Conor Posted July 2 Posted July 2 Depends on the valuation. The getting out of the ground stage is the most expensive part, but also adds the least value. You really want some walls built before you get the valuer out. Get as much money as you can at each stage. Our biggest regret is not drawing down more!!! 1
deancatherine09 Posted July 3 Posted July 3 (edited) On 02/07/2026 at 00:16, PSC88 said: Hi anyone with expertise with ecology stage valuations and draw downs? they don’t follow typical stages or give a clear indication of how much they will release at each stage only that they will release funds as the build progresses. i have a mortgage that will release up to 65% of the value at any one stage. i drew down the max 65% of my plot valuation to clear my previous residential mortgage (knock down and rebuild) and this left a small buffer to commence the build. i have enough funds to get to foundation and block and beam using the buffer and personal savings. im planning on then getting them out to value and release funds. The question is will they release enough to get to the next stage! And what stage would I then be calling them out again? my build is quite heavy in the earlier stages up to wind and watertight and would be great if I could budget effectively . Exactly that. They will release up to the 65% of the value they deem it at the time. Ours was 80% but worked the same, say value is £500k, they would release up to £400k and so on. You can have them out as many times as you want to do a valuation to release more funds but obviously they charge a valuation fee each time. Edited July 3 by deancatherine09
PSC88 Posted July 3 Author Posted July 3 Did you find the valuations were sufficient to progress your build? my only concern is they deem the valuation lower then the funds needed to progress to next stage
deancatherine09 Posted Monday at 17:35 Posted Monday at 17:35 It depends on your build method. We had Timber Frame - all payable before it even arrived on site so it was a bit touch and go at times - but we had a fair buffer to start with! A traditional build would be a lot easier. 1
Mr Punter Posted Tuesday at 09:29 Posted Tuesday at 09:29 I think you may need additional funding to stop the project running into the sand. If you share some figures it may help. You will need to get valuations that are in excess of the amount you have spent, so including a proportion of the future finished value may help.
Conor Posted Tuesday at 15:03 Posted Tuesday at 15:03 On 03/07/2026 at 19:01, PSC88 said: Did you find the valuations were sufficient to progress your build? my only concern is they deem the valuation lower then the funds needed to progress to next stage We (un)subtlety told the surveyor the valuation we needed. He did this on all bar one occasion. 1
PSC88 Posted Thursday at 21:09 Author Posted Thursday at 21:09 (edited) My plot was valued just under £800k. i was released circa £510k which was my max draw down of 65% I used this to clear my previous resi mortgage and pay for warranty and initial site enabling and Groundworks. i will be at block and beam (at a push first lift) when I request the second draw down. my end value has been conservatively placed at just over £2mill and my initial valuation report stated wind and water tight would value at 1.5mill Im restricted to max 65% draw down. my ideal scenario would be by end of 1st lift they value at £1.2 mill this should carry me to shell stage with roof covering complete and then just windows and doors to fund myself. Edited Thursday at 21:12 by PSC88
Havkey100 Posted 3 hours ago Posted 3 hours ago I must admit we are running into something similar with Ecology. We were given a land valuation that honestly was much lower than is reasonable for the area. We are putting a large 4 bed on a 700m2 plot and Ecology valued it at £115k. Initially I didn't really care as I wanted to get going with the build. In practice, if I tried to purchase a similar plot in the area I would be looking at £200k+. Our first draw down was £90k based on the land value. With the benefit of hindsight I would have questioned this more, as it really would have given us more breathing room. The overall build valuation also seems light for the area, as for the same size house on a similar plots I see asking prices about 30% above our valuation. We completed the ground works and slab and have just had the valuation for the the second draw down. The first draw down barely covered the cost of the slab, ground works and prelims. We expect that the valuation may barely release what we need to complete the superstructure, when our next major bill drops. After that, it seems we need to time the completion of the watertight shell perfectly so that we can get the valuer back out. Honestly, it all seems backwards. We have the funding in place to cover everything we need, our builder works in arears, with payment typically due 1 week after the end of the month. However, the build is fast, and I feel like the lending structure leaves a potential bridging gap. It is not big, but runs a few weeks behind what I would really prefer. I haven't really worked through the solution. We have access to the funds if needed, but I didn't expect to have to sell shares to cover these timing gaps.
Mr Punter Posted 2 hours ago Posted 2 hours ago 1 hour ago, Havkey100 said: I didn't expect to have to sell shares to cover these timing gaps. At least the shares are quick, cheap and simple to sell and purchase. Land and property is not any of these.
