G and J Posted 19 hours ago Posted 19 hours ago We need a fan coil, in our bedroom. It was always part of the plan, so we have ‘lecky and pipes laid ready, but I can’t find one. I know that sounds dumb and maybe I am missing something obvious. But I can’t find one. So I need help. The brief: a 2 pipe fan coil which can be hung from a ceiling. Needs to be less than a meter wide. I identified the Myson iVector 2, which may have been perfect, but that’s not available, and they can’t even predict when it will be. And I simply can’t find an alternative. Help!
JohnMo Posted 18 hours ago Posted 18 hours ago Cool Energy do them. Panasonic and Daikin maybe, pretty similar to the Myson iVector 2. Have a look at Orion Air sales also they do a range of them.
dpmiller Posted 15 hours ago Posted 15 hours ago hung from a ceiling- are you doing cooling and have you got a condensate drain?
G and J Posted 15 hours ago Author Posted 15 hours ago Yes, hung from a ceiling; to do cooling and no condensate drain, plan to run above dew point
Nickfromwales Posted 11 hours ago Posted 11 hours ago 4 hours ago, G and J said: Yes, hung from a ceiling; to do cooling and no condensate drain, plan to run above dew point This unit would need to be able to run independently, so plan the controls well, and manage your expectations of efficiency and ‘short-cycling’ even better. These things should have been ‘on the M&E menu’ at day dot tbh.
G and J Posted 10 hours ago Author Posted 10 hours ago 11 minutes ago, Nickfromwales said: These things should have been ‘on the M&E menu’ at day dot tbh. It was, and I identified the unit I intended to buy. Just not available. Sigh. I’ll get there.
Nickfromwales Posted 10 hours ago Posted 10 hours ago 26 minutes ago, G and J said: It was, and I identified the unit I intended to buy. Just not available. Sigh. I’ll get there. Respectfully, you need to include a contingent, when planning a home for life. Filed under “shit keeps happening”. Explore early, discuss in advance, resolve, progress. Zero reason to fail if you prepare afaic.
nikotime Posted 2 hours ago Posted 2 hours ago Jaga Briza do ceiling mounted fan coils. Currently getting a quote for my build.
G and J Posted 2 hours ago Author Posted 2 hours ago 8 hours ago, Nickfromwales said: Respectfully, you need to include a contingent, when planning a home for life. Filed under “shit keeps happening”. Explore early, discuss in advance, resolve, progress. Zero reason to fail if you prepare afaic. I know who is to blame. Little, round, bald guy with a dodgy sense of humour. He got lumbered with the labels of Principal Designer and Principal Contractor but his real talent was as Head of Global Operations for On Site Catering and Sweeping. Humph. One tries…. 1
JohnMo Posted 2 hours ago Posted 2 hours ago 13 minutes ago, G and J said: I know who is to blame. Little, round, bald guy with a dodgy sense of humour. He got lumbered with the labels of Principal Designer and Principal Contractor but his real talent was as Head of Global Operations for On Site Catering and Sweeping. Humph. One tries…. That's no way to talk about @Nickfromwales
G and J Posted 1 hour ago Author Posted 1 hour ago 15 minutes ago, JohnMo said: That's no way to talk about @Nickfromwales If you think Welsh Nick is going to replace me as tea boy and cleaner you’ve got another thing coming. I’ve got a talent and I’m going to use it! One lump or two?
G and J Posted 1 hour ago Author Posted 1 hour ago 45 minutes ago, nikotime said: Jaga Briza do ceiling mounted fan coils. Currently getting a quote for my build. Brilliant. Thank you. I have googled and googled fan coils, fan convectors, hydronic terminals, heat pump convectors, and many other combinations and not seen them. I've had a look at their website, and it appears exactly what we need. I’ve had the same conversation repeatedly, and been met with confusion when I’ve tried to explain what we are trying to do. These guys appear to have already got it. @nikotime who are you getting a quote from?
