Anitha Posted June 24 Posted June 24 (edited) Hi , Please find the attached floor plan of our house. Is it possible to move the cloakroom(toilet) in kitchen to garage and make the kitchen bigger. And it would be nice if we could connect kitchen and utility room (2nd kitchen). Now we dont have direct access. We have to either go throuh garage or go outside and then enter into utility room. Is this a big change? Is it possible to do this within 10-15k please Edited June 24 by Anitha Missed pics
Mr Punter Posted June 26 Posted June 26 There is at least 1 structural wall to the WC and it will be supporting floors and / or walls above. Not a big deal but needs a structural engineer to look at. The second kitchen looks like an add-on. If it is not a properly built extension it may be better to remove and start again. It is a bit of a hotchpotch at the back and £10-15k does not buy you much nowadays unless you are keen on DIY and / or have family in the building trade. There are some architect / designers on here who may chip in. 1 1
Gus Potter Posted June 26 Posted June 26 6 hours ago, Mr Punter said: There are some architect / designers on here who may chip in. As you say it kind of looks like the house has been previously altered. Would need more info to comment further as an SE / try and put a ball park cost on this. 1
Nickfromwales Posted June 26 Posted June 26 6 hours ago, Mr Punter said: There are some architect / designers on here who may chip in. And over-opinionated Welsh folk On 24/06/2026 at 13:21, Anitha said: Is it possible to move the cloakroom(toilet) in kitchen to garage and make the kitchen bigger Anything is possible, you just need money, imagination, and good people to support and execute the work. The garage is referred to as being 'outside the heated envelope' of the main (habitable) dwelling, AKA a "cold" space. To move the WC out there requires you building a wall at the end of the garage to create a new 'partition'; this would require a full building regs application with a proposal from a general builder, for comment. The garage floor should be stepped down 100mm or so from the residential dwelling, so that would need insulation over, to bring it to an acceptable standard, plus insulation to the ceiling and any external wall you then create (a new wall inside the garage would be considered an 'outside wall' as it abuts the remaining 'cold' area of the garage. I've done plenty of these jobs over the years, and it is very simple tbh. So....to answer your question...."YES!". 1
Anitha Posted June 28 Author Posted June 28 On 26/06/2026 at 21:23, Nickfromwales said: And over-opinionated Welsh folk Anything is possible, you just need money, imagination, and good people to support and execute the work. The garage is referred to as being 'outside the heated envelope' of the main (habitable) dwelling, AKA a "cold" space. To move the WC out there requires you building a wall at the end of the garage to create a new 'partition'; this would require a full building regs application with a proposal from a general builder, for comment. The garage floor should be stepped down 100mm or so from the residential dwelling, so that would need insulation over, to bring it to an acceptable standard, plus insulation to the ceiling and any external wall you then create (a new wall inside the garage would be considered an 'outside wall' as it abuts the remaining 'cold' area of the garage. I've done plenty of these jobs over the years, and it is very simple tbh. So....to answer your question...."YES!". Thank you so much for the replies. Any idea how much this work would roughly costs?
Nickfromwales Posted June 28 Posted June 28 1 hour ago, Anitha said: Thank you so much for the replies. Any idea how much this work would roughly costs? Nope. Needs a building control application first, with support from an architect or architectural technician (the latter will be cheaper and simpler). Then, you reach out to a few 5-6 reputable local builders for estimates / quotes etc and come back here with the results for us to see who's good / bad / ugly. ONLY use a builder who will take you to other jobs, let you meet other customers, and avoid the cheapest quotes! 2 1
Nickfromwales Posted June 29 Posted June 29 3 hours ago, Anitha said: Thank you @Nickfromwales. Keep asking questions here The most stupid questions, are the ones you didn't ask us Help is here by the bucketload, so measure twice, cut once!!!! 1
torre Posted June 30 Posted June 30 Is there room to put the toilet under the stairs with a new door opening into the hall? That would keep the impact on any future other changes to a minimum. I'd think about whether what you can do now for that 10-15k will compromise any larger renovation in future
