Super_Paulie Posted Friday at 14:56 Posted Friday at 14:56 Shower tray from Victoria Plumbing. Under the waste is dog rough, will the seal be ok on this with enough CT1 on the rubber? Trap is McAlpine.
Super_Paulie Posted Friday at 17:05 Author Posted Friday at 17:05 Actually it looks like this "alternative" flange that came with the McAlpine might make the underside a non-issue?
Bonner Posted Friday at 18:55 Posted Friday at 18:55 Yes, not an issue. Mine was like that, the waste seals on the top but plumbers put loads of silicone on the underside as well. 1
Super_Paulie Posted Friday at 18:57 Author Posted Friday at 18:57 1 minute ago, Bonner said: Yes, not an issue. Mine was like that, the waste seals on the top but plumbers put loads of silicone on the underside as well. Did you use the alternative seal like in the photo or just the 2 singles can you recall?
Bonner Posted Friday at 18:59 Posted Friday at 18:59 I don’t recognise the top hat seal so pretty sure it was two separate seals
Super_Paulie Posted Friday at 23:13 Author Posted Friday at 23:13 What's your take on this @Nickfromwales? CT1 on the trap rim, add the seal, then a bolt load of CT1 on the seal to fill in all that irregularity. Then bring that up to the tray and screw the top clamp ring in bringing the 2 together? There's a top seal as well, not sure that's necessary. Or use that "all in one" seal which came with it, described as "an alternative seal" that seems to traverse from top to bottom, essentially 2 seals joined together with a middle section, I'm sure you'd have seen them. The trap is McAlpine low profile.
Nickfromwales Posted Saturday at 16:14 Posted Saturday at 16:14 16 hours ago, Super_Paulie said: What's your take on this @Nickfromwales? CT1 on the trap rim, add the seal, then a bolt load of CT1 on the seal to fill in all that irregularity. Then bring that up to the tray and screw the top clamp ring in bringing the 2 together? There's a top seal as well, not sure that's necessary. Or use that "all in one" seal which came with it, described as "an alternative seal" that seems to traverse from top to bottom, essentially 2 seals joined together with a middle section, I'm sure you'd have seen them. The trap is McAlpine low profile. First off, NEVER use silicone for this, and always use a product such as CT1. Silicone has a very short life expectancy in comparison. Usually the underside of the tray is ground down to a flat surface, waaaaaay better than that pic shows, but it’s not life or death. As above the underside isn’t of paramount importance as the primary sealing is done at the top surface, but be sure to apply a smear of CT1 the top of the trap before tightening it up against the black rubber washer. 1
Super_Paulie Posted Tuesday at 22:18 Author Posted Tuesday at 22:18 On 13/06/2026 at 17:14, Nickfromwales said: As above the underside isn’t of paramount importance as the primary sealing is done at the top surface it seems pretty important in this instance, the trap doesnt have a screw in central funnel from top to bottom but looks more like it relies on the seals. The bottom seal looks like it does the brunt of the work to me? Id ditch the top seal and use CT1 I'd imagine as well, as I'd want it as low as possible in the recess.
Nickfromwales Posted 17 hours ago Posted 17 hours ago On 12/06/2026 at 18:05, Super_Paulie said: Actually it looks like this "alternative" flange that came with the McAlpine might make the underside a non-issue? Which one are you fitting? The above is what I commented on, so are you using the two loose seals or the above?
Super_Paulie Posted 15 hours ago Author Posted 15 hours ago (edited) i guess im open to offers on which one... the "top hat" one is quite loose fitting around the middle shaft (too tall for the trays depth) unless i add in one of the additional seals underneath the bottom side it to pad it out. So it comes with 3 seals, rough image attached. The first 2 are i guess a set of one for the top and one for underneath. The third one is the one in the picture above, the "all in one" described as "alternative seal H". Bizarrely i cant find any real reference or pictures of the 2 seals, i wonder if they have stopped shipping the trap with the two options now, i got mine from ebay instead of off the shelf, could have been old stock but it is referenced in the paper manual that came with it as "alternative seal H". Ideally id not have a top seal at all to keep the flange as flat as possible but if i need it then so be it, being bombproof takes priority for this. To add further issues, the counter-sunk screw holes in the top metal flange obviously direct down over which means it doesnt drop in totally flat. Id have to file the tray away at the points the countersunk sections sit, just a few mm) Edited 14 hours ago by Super_Paulie
Super_Paulie Posted 14 hours ago Author Posted 14 hours ago (edited) countersunk screws in flange fouling on tray mating surface. Use a file to take the tray down in these locations? only a few mm. Why is nowt easy. Edited 14 hours ago by Super_Paulie
Super_Paulie Posted 7 hours ago Author Posted 7 hours ago In reference to my last post there. VID_20260617_174608.mp4
Super_Paulie Posted 6 hours ago Author Posted 6 hours ago Proof is in the puddin, this thing isn't leaking even though it's under water. Overthinking things as per. 1
Nickfromwales Posted 5 hours ago Posted 5 hours ago 1 hour ago, Super_Paulie said: Proof is in the puddin, this thing isn't leaking even though it's under water. Overthinking things as per. Crack on and get it fitted boyo. 👍👌 Defo put a smear of CT1 on everything though, cheap insurance. Have cheap baby wipes to hand for clean up.
Super_Paulie Posted 5 hours ago Author Posted 5 hours ago 1 minute ago, Nickfromwales said: cheap baby wipes Sainsbury's own good enough for ya?
Nickfromwales Posted 5 hours ago Posted 5 hours ago 6 minutes ago, Super_Paulie said: Sainsbury's own good enough for ya? M&S.
MikeSharp01 Posted 3 hours ago Posted 3 hours ago I smoothed our daughters tray underside, which was awful, with isopon and a piece of plate glass, dead flat, to ensure we had a perfectly flat surface to mate with the trap, seems to have worked - all done dry- no ct1 and no leaks 4 years on. 1
