I am looking for Traditional Raised Panel aluminum door in black
Looking for a premium, domestic aluminum front door fabricator or supplier who can replicate the traditional/geometric style shown in the attached image (Front Door Traditional Aluminum .jpeg).
Please send over a quote if you can supply (or supply and fit) the following exact specifications:
๐Ÿšช GENERAL SPECIFICATIONS:
  • Material: 100% Aluminium Body (Lightweight domestic profile preferred)
  • Design Style: Traditional Geometric Raised Panel Design (See attached Front Door Traditional Aluminum .jpeg)
  • Layout: Single Door + 1 Integrated LEFT Sidelight (Built within a single outer frame)
  • Opening Direction: Left hand, opening inwards
๐Ÿ“ EXACT DIMENSIONS:
  • Overall Structural Width: 1500 mm
  • Overall Structural Height: 2000 mm
  • Actual Door Leaf Width: 1100 mm
  • Left Sidelight Width: 400 mm
  • Door Height: 1975 mm (To accommodate the cill)
๐ŸŽจ COLOUR & FINISH:
  • Slab & Frame Colour (Internal & External): Jet Black (RAL 9005 Matt or Fine Texture)
  • Cill: 134mm colour-matched black aluminium cill
  • Glass Type (Sidelight): Satin / Frosted Privacy Glass
๐Ÿ”’ HARDWARE & LOCKING:
  • Main External Handle: Central Round Pull Knob (As pictured in Front Door Traditional Aluminum .jpeg)
  • Hardware Finish: Satin Brass / Brushed Gold
  • Internal Handle: Standard Lever Handle (Black or Satin Brass)
  • Locking Mechanism: Automatic multi-point slam-shut lock
  • Cylinder: Thumbturn cylinder
  • Hinges: Slimline Roller Hinges
๐Ÿ’ฌ PLEASE QUOTE SEPARATELY FOR:
  1. Supply Only
  2. Full Installation (Location: [Insert your rough location, e.g., Reading / Berkshire])
  3. Please also confirm your current manufacturing lead times.
We donโ€™t allow people to advertise or sell on the site but someone might be able to suggest a supplier that you can contact.
