June 4Jun 4 Looking for a premium, domestic aluminum front door fabricator or supplier who can replicate the traditional/geometric style shown in the attached image (Front Door Traditional Aluminum .jpeg). Please send over a quote if you can supply (or supply and fit) the following exact specifications: ๐ช GENERAL SPECIFICATIONS: Material: 100% Aluminium Body (Lightweight domestic profile preferred) Design Style: Traditional Geometric Raised Panel Design (See attached Front Door Traditional Aluminum .jpeg) Layout: Single Door + 1 Integrated LEFT Sidelight (Built within a single outer frame) Opening Direction: Left hand, opening inwards ๐ EXACT DIMENSIONS: Overall Structural Width: 1500 mm Overall Structural Height: 2000 mm Actual Door Leaf Width: 1100 mm Left Sidelight Width: 400 mm Door Height: 1975 mm (To accommodate the cill) ๐จ COLOUR & FINISH: Slab & Frame Colour (Internal & External): Jet Black (RAL 9005 Matt or Fine Texture) Cill: 134mm colour-matched black aluminium cill Glass Type (Sidelight): Satin / Frosted Privacy Glass ๐ HARDWARE & LOCKING: Main External Handle: Central Round Pull Knob (As pictured in Front Door Traditional Aluminum .jpeg) Hardware Finish: Satin Brass / Brushed Gold Internal Handle: Standard Lever Handle (Black or Satin Brass) Locking Mechanism: Automatic multi-point slam-shut lock Cylinder: Thumbturn cylinder Hinges: Slimline Roller Hinges ๐ฌ PLEASE QUOTE SEPARATELY FOR: Supply Only Full Installation (Location: [Insert your rough location, e.g., Reading / Berkshire]) Please also confirm your current manufacturing lead times.
June 6Jun 6 We donโt allow people to advertise or sell on the site but someone might be able to suggest a supplier that you can contact.
