Makeitstop Posted 21 hours ago Posted 21 hours ago As above. Sorry, not really researched this as yet. It was a discussion i had recently. Question relates to a project my daughter has coming up, which is a sizeable job. She seems to think PVC can do this, but to my mind (and poor memory) its too large. Its been a few years since i did my own job, where i used Reynaers slider. Anyone have views on this?
Spinny Posted 20 hours ago Posted 20 hours ago If someone is having an opening as large as 7m by 2.7m, I can't really fathom why they would WANT PVC rather than aluminium.
Marvin Posted 20 hours ago Posted 20 hours ago Not sure that the PVC will take the weight of the glass....
Makeitstop Posted 17 hours ago Author Posted 17 hours ago It would be maybe 3.5 metres total width, perhaps 4 metres max. Height approx 2.7 maybe
Spinny Posted 14 hours ago Posted 14 hours ago As any limit will apply to any one single door with the total width of the opening being irrelevant, and you said 3.5m, I assumed you must be referring to a minimum opening of 7m with two 3.5m wide sliding doors. With a sufficient number of doors, doubtless you could do it in PVC e.g. 7 sliding doors each 0.5m wide. Probably going to look a bit shit though. Are you thinking of two doors each 1.75m wide and 2.7m high ? Or perhaps 3 doors each 1.2m wide, requiring three tracks ? Maybe type ''how wide can a upvc sliding door be'' into google AI ?
torre Posted 11 hours ago Posted 11 hours ago Plastic lift and slide like Aluplast will probably be able to handle that size / height and have decent u-values but may not be any cheaper than the popular aluminium systems and will definitely have bigger profiles.
