carlos21 Posted May 12 Posted May 12 Looking for thermally broken fixings that stop cold bridging, I used some hammer in nails that went into a large rawl plug and had a plastic cap on the nail, but i wasnt that impressed with the thermal break to be honest. Anyone use some they were happy with? Thanks carl
Gus Potter Posted May 12 Posted May 12 Have a look here, they may have something that floats your boat. https://www.ejot.co.uk/ If not on their website use that old thing called the telephone and give them a call. 1
saveasteading Posted May 13 Posted May 13 10 hours ago, carlos21 said: but i wasnt that impressed with the thermal break What is the context? What is being connected? Materials, and why you are concerned?
carlos21 Posted May 15 Author Posted May 15 Sorry for slow reply Iam fixing insulated plasterboard to stonewalls mostly and some on concrete blocks. The fixings i have used in the past created tiny black spots from condensation from cold bridging.
Gus Potter Posted May 15 Posted May 15 Fixing insulated platerboard directly to stone walls is likely to give you a pile of problems further down the line. Fixing to concrete blocks has similar risks. Best thing you can do it to post more info. Just draw a sketch on A4 paper, photograph it and post. You won't get tested on your drawing skills.
Super_Paulie Posted May 16 Posted May 16 I used foam onto my concrete blocks but regs said I needed to use mechanical fixings as well. If you're not getting it checked I'd just use the foam personally.
ADLIan Posted May 16 Posted May 16 Please do not omit the fixing(s) - it's only one or 2 per board (check MIs). In a fire any plastic insulation attached to the plasterboard will melt or soften and the plasterboard may fall off the wall. This exposes more fuel to a fire (combustible insulation) and blocks possible escape routes. Additionally it could be a major hazard for fire fighters if they have to enter the building if people reported in there. 2
carlos21 Posted May 30 Author Posted May 30 Thanks for the replies, sorry slow to get back, yes i will and have used mechanical fixings in conjunction with spray foam, i find the foam great on uneven stone. In terms of whether its a good idea to put insulated pb onto stone, im still not sure and have spent a long time thinking about it, but i wasnt sure about the whole lime render thing either. I wont be doing large areas mostly just window reveals. On a side note does dot n dabed normal plasterboard need mechical fixings too.?
Super_Paulie Posted June 1 Posted June 1 On 30/05/2026 at 19:47, carlos21 said: On a side note does dot n dabed normal plasterboard need mechical fixings too.? nah, you'll be reet.
