Spinny Posted 16 hours ago Posted 16 hours ago How can you remove a trickle vent to give access around it for painting ? - See photo.
torre Posted 15 hours ago Posted 15 hours ago Have had similar and I'm pretty sure that the caps on each side slide off sideways to reveal a screw below. You'll probably need to insert a thin flat screwdriver or blade to prise the joint open as they click into place when fitting. 1
craig Posted 2 hours ago Posted 2 hours ago 12 hours ago, torre said: Have had similar and I'm pretty sure that the caps on each side slide off sideways to reveal a screw below. Correct, that's the same for the external canopy.
