April 29Apr 29 Hi we have the house up and ramp entrance to porch. Driveway is gravel because sisters site is up to ground level and hopefully will be tackled soon. We really just want the length of the house at the back with some surface we can walk on and not spend a fortune. Hard ask I know these days. Have a groundsman gonna come and clear rubble, do dropped kerb etc. But he suggested putting 20mm gravel in back. its about 7ft between the house and the hedge and about 50ft long. Any suggestions other than 20mm gravel? Our budget is tight. Climate is wet so saw some 10mm granite stone, far nicer in a stately home with I think 2 x 4 Edited April 29Apr 29 by CalvinHobbes
April 29Apr 29 Second hand slabs from facebook I laid a patio a couple of years ago, slabs where a £1 each, bang them down on some weak mortar and live with them for a couple of years.
April 29Apr 29 Think long term. If it's going to be paved or concrete it will need a hardcore base. You could just lay and compact hardcore and walk on that until you can afford to finish it. Just avoid dusty crushed limestone as it can get a bit slick when wet. Perhaps go for MOT 3 which is free draining?
April 29Apr 29 Author We have some damaged scaffodling board so i was thinking of ripping some lengths and treating it then using it as a border with the bigger gravel beside the house and 10mm on path followed by another board. Would that look ok? How do the boards sit upright? How are they secured?
April 30Apr 30 Author Temp 14 hours ago, Temp said: Think long term. If it's going to be paved or concrete it will need a hardcore base. You could just lay and compact hardcore and walk on that until you can afford to finish it. Just avoid dusty crushed limestone as it can get a bit slick when wet. Perhaps go for MOT 3 which is free draining? Thank you, the more I understood and thought about what you said it's brilliant. I dont know if we can put it against the house though, maybe we need to come out a bit and use 2 x 4 or strips of scaffolding in between? Then later on we can get this down on top of the subbase https://www.mcmonaglestone.com/products/14mm-rose-gold-stone-chippings-tonne?pr_prod_strat=pinned&pr_rec_id=dc9ca52c5&pr_rec_pid=9597265084743&pr_ref_pid=9597264527687&pr_seq=uniform Again, thank you!
