We’re covering a small area of UFH (which was too shallow to lay the dry screed) with self levelling compound. In searching about SLC I’ve seen mention of a primer - is this always needed? The SLC will be onto a slip membrane which is over the pipes.
This is the stuff I’ve been recommended to use.
The primer is for priming up the surface if you are putting the SLC onto another concrete or screed surface.
If you are going over a plastic membrane nothing is going to stick to it, your SLC will always be an independent slab on top of the ufh.
How thick (or thin) is this going to be?
Also, you cant use primer over a membrane. ;)
I can’t recall your foundation type, but if theres a DPM under the slab you should cut the slip membrane out and put the SLC down without any such decoupling.
probably end up being about 30-40mm.
Foundation is a suspended beam & block floor, DPM, 150mm PIR, Vapour membrane, UFH, slip membrane.
