Alan Ambrose Posted Monday at 18:04 Posted Monday at 18:04 OK another tech question... We have a 50mm services void. I was planning to run horizontal cable trays, mostly high-up (2.5m above the floor) and split into mains & ELV / data (either using one split tray or two separate trays). Then a few vertical drops to light switches etc, also in trays if I can. And then fill any remaining void with, say, mineral wool. Question is - how do I avoid the mains crossing the data or is that OK? Something like this: Mains ------------------------!------------------------------- Data ------------------------!---------------!---------------- ! ! ! ! Mains Socket Network Port
garrymartin Posted Monday at 19:14 Posted Monday at 19:14 Perfectly fine. Crossing has fewer issues than running in parallel, and even that is not a big deal given the number of cables and voltages we are talking about in residential construction. 1
ProDave Posted Monday at 20:55 Posted Monday at 20:55 BUT electric cables must tin in safe zones. So to ensure this the electric cable tray must be within 100mm of the ceiling all the way across the room. The data cable tray can be at any height you want. 1
Alan Ambrose Posted 18 hours ago Author Posted 18 hours ago >>> the electric cable tray must be within 100mm of the ceiling Ah, I was assuming some common sense on this - we’re vaulted pretty much everywhere with a slopey ceiling from about 3.5m at the eaves. I was planning on putting the trays above the doors at about 2.4m.
Alan Ambrose Posted 18 hours ago Author Posted 18 hours ago p.s. I was thinking re safety standards / British standards / building control etc rather than interference problems. I see a typical summary e.g. here: https://www.cablemonkey.co.uk/cmdocs/ElectricalDistance.pdf But it has so many cases, it’s really hard to follow.
ProDave Posted 17 hours ago Posted 17 hours ago 1 hour ago, Alan Ambrose said: >>> the electric cable tray must be within 100mm of the ceiling Ah, I was assuming some common sense on this - we’re vaulted pretty much everywhere with a slopey ceiling from about 3.5m at the eaves. I was planning on putting the trays above the doors at about 2.4m. Electric cables in a wall must run in a safe zone. Broadly speaking a safe zone is horizontally or vertically from an electrical accessory, e.g. a socket, or within 100mm of the corner of a room or ceiling. If you want to run electric cables around a room then do so at socket height, and ensure each wall has at least one socket to create that safe zone, and that is where all your mains cables can correctly run around a room.
