Spinny Posted 18 hours ago Posted 18 hours ago Anyone recommend a good flexible decorating sealant tha takes emulsion paints e.g. to use at junctions such as plaster and rooflight, skirting/architrave and wall etc etc
Nickfromwales Posted 8 hours ago Posted 8 hours ago 10 hours ago, Spinny said: Anyone recommend a good flexible decorating sealant tha takes emulsion paints e.g. to use at junctions such as plaster and rooflight, skirting/architrave and wall etc etc It’s called “decorators caulk”. More severe gaps should be filled and finished with Tupret filler. https://www.screwfix.com/p/bostik-acrylic-instantly-paintable-decorators-caulk-white-310ml/756je?ref=SFAppShare https://www.screwfix.com/p/toupret-quick-dry-filler-2kg/763pp?ref=SFAppShare I should add, if you’ve chosen your plasterer very well, same for the carpenter, you should need very little of either. 1
saveasteading Posted 3 hours ago Posted 3 hours ago I don't know the Toupret product so used your link. The description says it 'does not flash or grin' . That's good to hear, except I don't know what that means in this context. Do you know?
