BotusBuild Posted 4 hours ago Posted 4 hours ago Following a water leak, we have a log burner that has developed a patina of rust on the door and frame. We're going to give it a gentle clean to start with to see what the extent of the problem, thinking it's likely just surface rust from the moisture that was in the air. Is there a paint that anyone can recommend once the rust is removed?
Nickfromwales Posted 4 hours ago Posted 4 hours ago VHT (Very High Temperature) paint is used on exhausts and the such, so start there.
Beau Posted 4 hours ago Posted 4 hours ago (edited) Black stove paint is widely available. Our local farm shop even stocks it (least they used to) and they have a branch in Liskeard which might be close to you? Mole Valley Farmers Edited 4 hours ago by Beau
BotusBuild Posted 1 hour ago Author Posted 1 hour ago 2 hours ago, Nickfromwales said: VHT (Very High Temperature) paint is used on exhausts and the such, so start there. That was my initial thought also
BotusBuild Posted 1 hour ago Author Posted 1 hour ago 2 hours ago, Beau said: Black stove paint is widely available. Our local farm shop even stocks it (least they used to) and they have a branch in Liskeard which might be close to you? Mole Valley Farmers They are close by (in Cornish terms). Wonder if they have it gun metal grey
crispy_wafer Posted 1 hour ago Posted 1 hour ago Back in the day, we used to use hotspot black grate polish to rub into the castings. The rust would only ever be surface dusting of corrosion on the old hunter and Dunsley’s and would pretty much disappear when rubbing a finger over it.
FarmerN Posted 1 hour ago Posted 1 hour ago Googleing "log burner stove polish" brings up a range of products. Back in the days, I'm sure we had "Stove Black" no idea what it was.
