Saints1 Posted March 19 Posted March 19 Hello, I wondered if somebody could help or offer some advice. we are just digging out for our self build plot. The foundation is a raft design and as we have dug close to the neighbouring boundary (their drive way) we have located a 110mm pipe with a blanking cap on the end coming on to our land by about 1 meter. Now I know the neighbouring property was built in 2020 and at the time the guy who built it was also hoping to build on the land that we are now developing but he was refused planning. I am wondering if he was future proofing it at the time in the hope he would get planning. There is an inspection chamber on the neighbouring properties driveway approximately 3 meters from where I have discovered the pipe on my land. My question are; 1. Am I able to connect on to it? 2. Do I need to notify the utilities company? just for context the whole road is on a combined system, unfortunately the ground isn’t suitable for a soakaway to be installed (SUDS) as it’s got clay all over the land. 3. Am I able to send/direct both foul and rainwater to this pipe? any help or assistance is greatly appreciated?
Nickfromwales Posted March 19 Posted March 19 You'll need to find out if it's 'adopted' or not. Contact the utility company and then if it's adopted then you should be able to connect into it. Will be a gift if you can.
Saints1 Posted March 19 Author Posted March 19 I contacted the utilities company some months back to get a drainage plan from them. Unfortunately they hold no plans until around 4 doors down. I know that the main drainage route/pipe goes through the back of the gardens until 4 doors down and then kicks out to a big inspection chamber at the back in a farmers field. (This is were the utilities have their plans from) The utilities company said that this will be because the pipe is on private land that they’ll hold no record. My only current issue I have is the utilities company won’t discharge my final pre-commence by condition until they seen my full drainage plan. Which is fine but they are adamant I have to explore all avenues in soaking away the rain water, despite having trial holes dug for soil sampling which states the ground is unsuitable for a buried soak away.
Nickfromwales Posted March 19 Posted March 19 6 minutes ago, Saints1 said: I contacted the utilities company some months back to get a drainage plan from them. Unfortunately they hold no plans until around 4 doors down. I know that the main drainage route/pipe goes through the back of the gardens until 4 doors down and then kicks out to a big inspection chamber at the back in a farmers field. (This is were the utilities have their plans from) The utilities company said that this will be because the pipe is on private land that they’ll hold no record. My only current issue I have is the utilities company won’t discharge my final pre-commence by condition until they seen my full drainage plan. Which is fine but they are adamant I have to explore all avenues in soaking away the rain water, despite having trial holes dug for soil sampling which states the ground is unsuitable for a buried soak away. Show them the pipe, where it goes, and that next door is also on a combined network sewer. You can provide percolation test results, DIY'd, to fortify. 1
saveasteading Posted March 20 Posted March 20 What happens currently with rain that falls on the site? It goes somewhere.
torre Posted March 20 Posted March 20 So the inspection chamber and pipe were both in place before the neighbour bought the property? As the chamber is unadopted I'd start by having a conversation with the neighbour, outlining this was put in by the builder ready for connecting to your property and letting them know you want to apply to connect to it. Be clear that after adoption the water company will be responsible for any problem with the chamber or the sewer, and that while you don't expect any work on their property is needed, you'd reinstate/compensate if it is. Hopefully the neighbour will be reasonable. One thing I've bumped into is that adoption may limit what cover is allowed - our water company wouldn't adopt unless we swapped ours from a recessed one you could lay blocks into for a flat cover that's not so aesthetically pleasing. Water company may well want you to install a storm attenuation tank even if they do allow rainwater into the sewer
saveasteading Posted March 20 Posted March 20 2 minutes ago, torre said: Water company may well want you to install a storm attenuation tank That would be good practice and ' the right think to do" for society even if not a condition. Rain in the sewers is what causes sewage works overflows. Have you room for a pond?
Nickfromwales Posted March 20 Posted March 20 5 minutes ago, saveasteading said: Have you room for a pond Would probably still need attenuation for when the pond is full?!? 1
ToughButterCup Posted March 20 Posted March 20 Talk. Listen. Come back to us with the result if needed.
saveasteading Posted March 20 Posted March 20 2 hours ago, Nickfromwales said: still need attenuation for when the pond is full?!? Yes. But fundamentally the water is going somewhere now, or sitting on top and evaporating. French drains feeding a pond then an overflow with a hydrobrake going to sewer or ditch or... something. Without knowing a huge amount more it's guesswork.
