DannyT Posted 7 hours ago Posted 7 hours ago Our application is in for the new house design. Planning have emailed to say it’s all ready to wrap up apart from requiring a energy statement from a registered assessor. Does anyone have any recommendations? I have most of the figures from the heat loss spread sheet off buildhub but obviously I’m not registered 🙈 Thank you in advance 👍🏻
JohnMo Posted 7 hours ago Posted 7 hours ago Ask your architect - he should have standard words. If you are at planning stage in Scotland, that should be all that's needed. When you get to warrant stage you will need 'as designed' EPC and once built that converted to 'as built'. It's a tick box exercise at planning stage. But if you say your going airtight, they will expect to understand your journey to get there and what products you plan to use with datasheets.
