Batteries in plant room and 120 minute fire rated walls
4 minutes ago, jimseng said:
The interesting thing about much of the discussions about fires and Lithium batteries is that they never seem to refer to LiFePo4 batteries.
Completely anecdotal but I've seen more reports of fires from loose connections on 48V wiring to batteries than I have of LifePo4 batteries burning.
2 minutes ago, saveasteading said:
Or that fire extinguisher as above, but somehow automatically. Someone could sell these.
The Fogstar batteries I have just bought have this built in.
1 minute ago, saveasteading said:
So a water spray at an early stage could reduce the temperature enough
That is what I was questioning.  I don't know the answer.
The key words there are "anecdotal" and "loose connections". Putting 32kw of energy in a small box carries a risk that if you allow it to escape quickly and uncontrolled it is probably going to say "boom". That is the same for Lead acid batteries, which also give off very nasty gas when they go wrong.
Heath Robinson could do this.
Fire burns through string supporting extinguisher, which topples forward onto its lever which opens it and the fire goes out.,
It would be better if every supplier included a self-extinguishing system, and insurance cover for house and contents.
