Temp Posted Friday at 18:59 Posted Friday at 18:59 Our shower glass has been etched by descaler over the years. Has anyone tried polishing/mopping out the frosting it produces? Have slow speed angle grinder/mop.
Nickfromwales Posted 14 hours ago Posted 14 hours ago On 27/02/2026 at 18:59, Temp said: Our shower glass has been etched by descaler over the years. Has anyone tried polishing/mopping out the frosting it produces? Have slow speed angle grinder/mop. A PITA, but if the glass IS actually etched, then maybe try mopping it with some G3 or G10 compound LINK as this is what I used to polish with cars back in the day when I worked for a high-end car sales as a detailer (when I had more hair and less creaky joints).
Onoff Posted 14 hours ago Posted 14 hours ago Jewellers rouge aka cerium oxide works a treat to bring up scaled glass. We used to use it to get cement stains off glass. It comes in different grit sizes. We once used coarse to fine getting burn marks out of glass that some lad had caused with angle grinder sparks.
Onoff Posted 14 hours ago Posted 14 hours ago Try this before cerium oxide: https://www.ungerglobal.com/uk/products/rub-out
Temp Posted 2 hours ago Author Posted 2 hours ago 11 hours ago, Onoff said: Try this before cerium oxide: https://www.ungerglobal.com/uk/products/rub-out Thanks but it's been cleaned within an of an inch of its life. Definitely etched.
Temp Posted 2 hours ago Author Posted 2 hours ago 11 hours ago, Onoff said: Jewellers rouge aka cerium oxide works a treat to bring up scaled glass. We used to use it to get cement stains off glass. It comes in different grit sizes. We once used coarse to fine getting burn marks out of glass that some lad had caused with angle grinder sparks. I have some 2.5 micron on the way. Will see how that goes.
