Oz07 Posted Monday at 10:45 Posted Monday at 10:45 Has anyone successfully ran any length of soil pipe perpendicular in pozi joists? Im thinking each cord being around 45mm gives you 135mm between so 25mm. Maybe gives you room for a couple of metres of fall at 1:80 if you can specify the metal webs to give you room. Just considering the design of something and which way to run joists. I've also seen jobs where the joists stop short of the wall by a couple of hundred mm and sit on a trimmer like a staircase. Maybe there's even some obscure pipe size you can use for waste like 90mm od?
Nickfromwales Posted Monday at 11:03 Posted Monday at 11:03 13 minutes ago, Oz07 said: Has anyone successfully ran any length of soil pipe perpendicular in pozi joists? Im thinking each cord being around 45mm gives you 135mm between so 25mm. Maybe gives you room for a couple of metres of fall at 1:80 if you can specify the metal webs to give you room. Just considering the design of something and which way to run joists. I've also seen jobs where the joists stop short of the wall by a couple of hundred mm and sit on a trimmer like a staircase. Maybe there's even some obscure pipe size you can use for waste like 90mm od? I do this on nearly every project, and never been an issue. BCO's tend to not really give 2 hoots about the drainage after you're above ground btw, with the last BCO stating to me "if it blocks they won't ring me they'll ring you". They just ask about access, air admittance, and after that they switch off. What distance do you need to travel between chords? 5m to 6m is easily doable as the flush velocity helps a lot, and 1:100 is fine as long as it's kept as a straight run. If there's need for change of direction to align with the voids, then do that at the WC end. A pic or plan would help. 1
Mr Punter Posted Monday at 11:12 Posted Monday at 11:12 You could use 82mm soil pipe to gain an extra 28mm. Plenty of fittings available. https://plasticsuppliesdirect.co.uk/soil-vent-systems/82mm-push-fit-soil-vent-pipe.html?p=2 1
saveasteading Posted Monday at 12:08 Posted Monday at 12:08 1 hour ago, Nickfromwales said: 1:100 is fine as long as it's But I'd be very precise and use lots of ties to the joists: wire or straps, so that it keeps the slope and doesn't ever sag. Maybe lay a timber under it where possible. 1
Oz07 Posted Monday at 15:45 Author Posted Monday at 15:45 Interesting. Just at very early planning stage so nothing concrete yet. I think the wall hung wcs have that 82mm soil pipe from memory? Can you come out of a normal wc pan into 82mm without problems? So my option is smaller waste or less fall. Max run would be 4m, prob a bit less. I'll have to remember to feed waste pipe in when putting joists on. I did it last time with a 2" pipe and small joists centres saved having to try thread it in after.
G and J Posted Monday at 22:49 Posted Monday at 22:49 I’m sure our geberit cisterns have a 90mm bend connector thingy which then pushes into a 110mm to 90mm reducer. Early in the process I’d planned a soil pipe through posijoists but realised it was just too difficult to actually fit so I replanned to avoid the need. 1
Nickfromwales Posted Tuesday at 08:58 Posted Tuesday at 08:58 20 hours ago, saveasteading said: But I'd be very precise and use lots of ties to the joists: wire or straps, so that it keeps the slope and doesn't ever sag. Maybe lay a timber under it where possible. I use a laser and all-round patent band, at around 1000mm cc. I try to avoid connecting it to the lower chord, so sound doesn't transmit to the GF ceiling. Geberit stuff is euro 90mm, whereas UK (3") is 82mm vs (4") 110mm. Regs say you can have 1x WC on a singe run of 82mm going to meet a 110mm SVP. Youd need to get a specific adaptor, if one exists, to go 90mm > 82mm, or go 90mm > 110mm > 82mm 82mm > 110mm adaptor I only ever use 3" if its a rising (dry) vent pipe, and it needs to go up inside a stud wall, or alongside a rainwater downpipe to 'match', vs doing it in the cumbersome 4"/110mm stuff. @Oz07, how long a run do you need through the posi's?
saveasteading Posted Tuesday at 15:15 Posted Tuesday at 15:15 My concern would be at the bend to the vertical pipe. The liquid runs fast and shallow around a bend and can leave solids behind. So it's just attention to detail with good fittings.
Oz07 Posted Tuesday at 19:52 Author Posted Tuesday at 19:52 10 hours ago, Nickfromwales said: @Oz07, how long a run do you need through the posi's? 4m max potentially get it down to 2m with different svp position. Nothing set in stone yet. When i read the regs its asking for 18mm in 1m for fall
