Onoff Posted February 12 Posted February 12 I need a couple of vented chimney cowls. Pot is 14" diameter. Any suggestions as to where, local roofing place ones are too small a diameter.
Onoff Posted February 12 Author Posted February 12 39 minutes ago, Nickfromwales said: I'm shocked that you haven't 3D printed them!!?? The printer will only print 256x256x256mm. Don't think I haven't thought of it. Mulling on printing 4, slip together quadrants that I could form cement over.
saveasteading Posted February 12 Posted February 12 3 hours ago, Onoff said: Any suggestions Are these working chimneys? Why do you want cowls? Rain and bird guards or spinning ones? For the former, I googled and found 250mm easily, I suspect you may need to reduce the diameter to suit the biggest you can readily find. It might look odd and not keep the rain out unless modified. OR the non-mechanical ones look very simple and could be modified at hood and the legs, or fabricated even.
Onoff Posted February 12 Author Posted February 12 Non working chimneys. Also considering making something like this:
Onoff Posted February 13 Author Posted February 13 Thinking to fire up the plasma in the morning and cut a say 16" circle out of some thin stainless sheet I have here as a start. Maybe drag the torch round an old wheel rim. Thinking won't a flat plate be noisy in the rain? Is a conical cowl necessary? I've no method either of rolling a downturn/lip on said disc.
saveasteading Posted February 13 Posted February 13 I'd say that using steel 2mm or thicker won't be noisy. For a cone, cut a segment from a circle and reweld and that won't be noisy either. Is a downturn going to help? Maybe just turning with pliers will do it in crinkly fashion.
Onoff Posted February 14 Author Posted February 14 23 minutes ago, saveasteading said: Maybe just turning with pliers will do it in crinkly fashion. That's a good shout actually. I've a cable tray setter I made when at college, that might do it.
saveasteading Posted February 14 Posted February 14 1mm thick stainless. Cut a radius line and lap the edges and rivet together for a cone. Then turn down the edges.
Nickfromwales Posted February 14 Posted February 14 2 hours ago, Onoff said: Butt welded That's how @Pocster got parole. 1
Pocster Posted February 15 Posted February 15 On 12/02/2026 at 15:09, Onoff said: I need a couple of vented chimney cowls. Pot is 14" diameter. Any suggestions as to where, local roofing place ones are too small a diameter. (expletive deleted) going up a ladder and standing on the roof
Pocster Posted February 15 Posted February 15 (edited) Always looks different at night Edited February 15 by Pocster 1
Onoff Posted February 15 Author Posted February 15 1 hour ago, Pocster said: Always looks different at night You have absolutely no idea how close to the truth you are. Buildings either side of that street have seen a fair bit of Police activity over the years. For what you're getting at is a couple of streets over. 1
Pocster Posted February 15 Posted February 15 30 minutes ago, Onoff said: For what you're getting at is a couple of streets over. Then you shouldn’t be (expletive deleted)ing about on a chimney stack . Jump over a few streets and get it in there my man ! 💪
Onoff Posted 13 hours ago Author Posted 13 hours ago Well it could do with being a tad tighter but it won't come off in a strong blow:
