Onoff Posted 7 hours ago Posted 7 hours ago I need a couple of vented chimney cowls. Pot is 14" diameter. Any suggestions as to where, local roofing place ones are too small a diameter.
Onoff Posted 3 hours ago Author Posted 3 hours ago 39 minutes ago, Nickfromwales said: I'm shocked that you haven't 3D printed them!!?? The printer will only print 256x256x256mm. Don't think I haven't thought of it. Mulling on printing 4, slip together quadrants that I could form cement over.
saveasteading Posted 3 hours ago Posted 3 hours ago 3 hours ago, Onoff said: Any suggestions Are these working chimneys? Why do you want cowls? Rain and bird guards or spinning ones? For the former, I googled and found 250mm easily, I suspect you may need to reduce the diameter to suit the biggest you can readily find. It might look odd and not keep the rain out unless modified. OR the non-mechanical ones look very simple and could be modified at hood and the legs, or fabricated even.
Onoff Posted 3 hours ago Author Posted 3 hours ago Non working chimneys. Also considering making something like this:
