JKami84 Posted Monday at 16:10 Posted Monday at 16:10 i have a timber subfloor - 18mm floorboards on joists. I'm having electric UFH in some of the area. I'd like some insulating properties to make the UFH heating more efficient. 1 tiler said he would only use 6mm hardiebacker cement board. another tiler said he would use 10mm Delta board (which is cement coated but foam centre). he didnt just say this for insulating, he said he prefers it as it 'absorbs' some movement. 1st tiler said only full cement board is rigid enough. he also said if i want insulating, will still need a cement board first - but this is not an option for the floor height. 2 views on the same puzzle.... its confused the hell out of me.
torre Posted Tuesday at 18:46 Posted Tuesday at 18:46 Not a tiler but we have successfully used the 10mm cement faced foam boards screwed to the floorboards with plenty of the large backer board washers, then a flexible tile adhesive and flexible grout. This was recommended to us on the basis there'll be a bit of movement with any timber floor, so better to allow for it - my concern with the cement boards is they may be more stable across the board itself, but that means any movement is focused more at the joints between boards. If you're having electric UFH and it'll only be on for short periods then I agree the insulation is a plus.
Nickfromwales Posted Tuesday at 21:19 Posted Tuesday at 21:19 On 09/02/2026 at 16:10, JKami84 said: i have a timber subfloor - 18mm floorboards on joists. I'm having electric UFH in some of the area. I'd like some insulating properties to make the UFH heating more efficient. 1 tiler said he would only use 6mm hardiebacker cement board. another tiler said he would use 10mm Delta board (which is cement coated but foam centre). he didnt just say this for insulating, he said he prefers it as it 'absorbs' some movement. 1st tiler said only full cement board is rigid enough. he also said if i want insulating, will still need a cement board first - but this is not an option for the floor height. 2 views on the same puzzle.... its confused the hell out of me. You just need 6mm or 10mm tile insulation (not cement backer) boards, set down into flexible tile adhesive over the original chipboard flooring (cleaned and primed with 50/50 water/PVA immediately before laying) and then put the UTH wire on to the insulation board and off to go. Done loads of these over the years, on concrete or timber, ground and 1st (and 2nd) floors, and no issues. You can tell when they lack experience, when they only quote directly what the manufacturer or rep recommends.
dave2878 Posted Tuesday at 21:34 Posted Tuesday at 21:34 forget the pva . never use it , its not fit for tiling , jacko board or other insulation board glued ans screwed . ufh fitted . staple though the netting to make sure it doesnt float , then self level ontop . then tiling after priming the self level. suitable primer sbr ect, definitely not pva
Nickfromwales Posted Tuesday at 21:39 Posted Tuesday at 21:39 1 minute ago, dave2878 said: forget the pva For tiling on to yes. For fixing and priming the substrates and underlayment, then its perfectly good! Been doing this for 30 plus years. Above those layers you use a tile primer such as Ultra, if it's needed. No need whatsoever to screw these boards down, does nothing but waste screws, time and money.
dave2878 Posted Tuesday at 21:59 Posted Tuesday at 21:59 cool got ye , i would just use normal primer anyway as i dont carry pva in van and i screw it but thats just preference, i either staple or rapid set ufh down as i have had them float before i never tile straight on in case i damage them . nice work 1
Nickfromwales Posted Tuesday at 22:15 Posted Tuesday at 22:15 16 minutes ago, dave2878 said: cool got ye , i would just use normal primer anyway as i dont carry pva in van and i screw it but thats just preference, i either staple or rapid set ufh down as i have had them float before i never tile straight on in case i damage them . nice work Been bitten once, so now I leave the multimeter hooked up whilst laying, if I'm not self levelling. I use mitre bond and activator to pin the UTH mats / wires down, as once the bastards float you're screwed! I use the grout float to skim the wires / mats so there's no metal trowel going against them, and always fit a second, redundant probe for the thermostat in case the original one carks it Thanks. Got the knees and back to show for it though! 1
JKami84 Posted Wednesday at 15:31 Author Posted Wednesday at 15:31 You guys have been helpful. It seems like the 10mm foam filled boards like marmox or delta board ARE sufficient for my bouncy timber floor ... Just as much as a cement board would be... And will provide some insulation. I also hear the benefit of foam filled for allowing flex of floor rather than cement board - so UFH or not , may still be a better choice. The area of the floor being UF heated (living space) is much less creaky or bouncy than the kitchen part .. so I also overthought thinking I'd use cement board in one part and foam one in the other part . Lol. I'm going nuts
dave2878 Posted Wednesday at 20:04 Posted Wednesday at 20:04 can you not lift a few of the floor boards and add in some dwangs to brace the floor and make it more rigid ,
dave2878 Posted Wednesday at 20:07 Posted Wednesday at 20:07 21 hours ago, Nickfromwales said: Been bitten once, so now I leave the multimeter hooked up whilst laying, if I'm not self levelling. I use mitre bond and activator to pin the UTH mats / wires down, as once the bastards float you're screwed! I use the grout float to skim the wires / mats so there's no metal trowel going against them, and always fit a second, redundant probe for the thermostat in case the original one carks it Thanks. Got the knees and back to show for it though! good idea on the mitre mate will have to try this . i fee; your pain with the knees and back 25 years of this has taken its toll
Nickfromwales Posted Wednesday at 20:26 Posted Wednesday at 20:26 4 hours ago, JKami84 said: You guys have been helpful. It seems like the 10mm foam filled boards like marmox or delta board ARE sufficient for my bouncy timber floor ... Just as much as a cement board would be... And will provide some insulation. I also hear the benefit of foam filled for allowing flex of floor rather than cement board - so UFH or not , may still be a better choice. The area of the floor being UF heated (living space) is much less creaky or bouncy than the kitchen part .. so I also overthought thinking I'd use cement board in one part and foam one in the other part . Lol. I'm going nuts The subfloor needs to be robust, so no loose screws / nails, and no excess movement. Nothing will survive a moving deck. If the deck is nailed down, then I’d punch a 5.0 x 60mm screw in where every nail is, right alongside it, and get the preparation done properly. Is the bounce because they’re original, smaller joists, or because the deck isn’t fixed down properly?
JKami84 Posted Wednesday at 22:44 Author Posted Wednesday at 22:44 There are a few creaks. I'll get them screwed down. Maybe one area of bounce. I don't think it needs screw for every board - which are nailed. But definitely a big bag of screws is a good idea. They need pilot holes I imagine. I put a few in and I think I made them worse as the board tried to lift
Nickfromwales Posted 21 hours ago Posted 21 hours ago (edited) On 11/02/2026 at 22:44, JKami84 said: There are a few creaks. I'll get them screwed down. Maybe one area of bounce. I don't think it needs screw for every board - which are nailed. But definitely a big bag of screws is a good idea. They need pilot holes I imagine. I put a few in and I think I made them worse as the board tried to lift You’re not pushing down hard enough on the drill / impact gun I expect. The lifting of the boards is called ‘jacking’ which sees the boards lift as if they were being ‘jacked’. This is usually where a fully threaded screw has been used vs a part-threaded screw. It does need a screw for every nail in every board, it’s called preparation. “Fail to prepare, prepare to fail”. I worked for a dickhead a good few years ago, and one thing he said always rang true….. ”Short cuts take 3 times longer”. Much as I hated it, he was right. Every time I tried in life to go the easy / quick route, I ended up pulling it all out and doing it all over again. I’m a stubborn bastard so I kept going against this, but it just came back to bite me and now I just do it right first time. Lecture over, put as many (or as few) screws in as you feel comfortable with Edited 1 hour ago by Nickfromwales
torre Posted 1 hour ago Posted 1 hour ago Something part threaded like these will drive in without a pilot hole and pull tight. 1
