JKami84 Posted Monday at 16:10 Posted Monday at 16:10 i have a timber subfloor - 18mm floorboards on joists. I'm having electric UFH in some of the area. I'd like some insulating properties to make the UFH heating more efficient. 1 tiler said he would only use 6mm hardiebacker cement board. another tiler said he would use 10mm Delta board (which is cement coated but foam centre). he didnt just say this for insulating, he said he prefers it as it 'absorbs' some movement. 1st tiler said only full cement board is rigid enough. he also said if i want insulating, will still need a cement board first - but this is not an option for the floor height. 2 views on the same puzzle.... its confused the hell out of me.
torre Posted 5 hours ago Posted 5 hours ago Not a tiler but we have successfully used the 10mm cement faced foam boards screwed to the floorboards with plenty of the large backer board washers, then a flexible tile adhesive and flexible grout. This was recommended to us on the basis there'll be a bit of movement with any timber floor, so better to allow for it - my concern with the cement boards is they may be more stable across the board itself, but that means any movement is focused more at the joints between boards. If you're having electric UFH and it'll only be on for short periods then I agree the insulation is a plus.
Nickfromwales Posted 3 hours ago Posted 3 hours ago On 09/02/2026 at 16:10, JKami84 said: i have a timber subfloor - 18mm floorboards on joists. I'm having electric UFH in some of the area. I'd like some insulating properties to make the UFH heating more efficient. 1 tiler said he would only use 6mm hardiebacker cement board. another tiler said he would use 10mm Delta board (which is cement coated but foam centre). he didnt just say this for insulating, he said he prefers it as it 'absorbs' some movement. 1st tiler said only full cement board is rigid enough. he also said if i want insulating, will still need a cement board first - but this is not an option for the floor height. 2 views on the same puzzle.... its confused the hell out of me. You just need 6mm or 10mm tile insulation (not cement backer) boards, set down into flexible tile adhesive over the original chipboard flooring (cleaned and primed with 50/50 water/PVA immediately before laying) and then put the UTH wire on to the insulation board and off to go. Done loads of these over the years, on concrete or timber, ground and 1st (and 2nd) floors, and no issues. You can tell when they lack experience, when they only quote directly what the manufacturer or rep recommends.
dave2878 Posted 2 hours ago Posted 2 hours ago forget the pva . never use it , its not fit for tiling , jacko board or other insulation board glued ans screwed . ufh fitted . staple though the netting to make sure it doesnt float , then self level ontop . then tiling after priming the self level. suitable primer sbr ect, definitely not pva
Nickfromwales Posted 2 hours ago Posted 2 hours ago 1 minute ago, dave2878 said: forget the pva For tiling on to yes. For fixing and priming the substrates and underlayment, then its perfectly good! Been doing this for 30 plus years. Above those layers you use a tile primer such as Ultra, if it's needed. No need whatsoever to screw these boards down, does nothing but waste screws, time and money.
dave2878 Posted 2 hours ago Posted 2 hours ago cool got ye , i would just use normal primer anyway as i dont carry pva in van and i screw it but thats just preference, i either staple or rapid set ufh down as i have had them float before i never tile straight on in case i damage them . nice work 1
Nickfromwales Posted 2 hours ago Posted 2 hours ago 16 minutes ago, dave2878 said: cool got ye , i would just use normal primer anyway as i dont carry pva in van and i screw it but thats just preference, i either staple or rapid set ufh down as i have had them float before i never tile straight on in case i damage them . nice work Been bitten once, so now I leave the multimeter hooked up whilst laying, if I'm not self levelling. I use mitre bond and activator to pin the UTH mats / wires down, as once the bastards float you're screwed! I use the grout float to skim the wires / mats so there's no metal trowel going against them, and always fit a second, redundant probe for the thermostat in case the original one carks it Thanks. Got the knees and back to show for it though!
