Jothetaxi Posted 2 hours ago Posted 2 hours ago Do you think this wall could be repaired or a section rebuilt? The tree roots have affected it quite significantly. Obviously the tree will be removed. Any suggestions or ideas welcome. Thanks.
Russell griffiths Posted 2 hours ago Posted 2 hours ago You can definitely replace a section, but no matter how good a bricklayer you find it will always look like a new panel. even if you find the exact brick match the original wall would have aged over time. depends if you can stand seeing a different colour section or if you have the funds to replace the lot.
Jothetaxi Posted 2 hours ago Author Posted 2 hours ago Thanks for the reply. Do you think brick cleaning would help to make it look less obvious?
Russell griffiths Posted 39 minutes ago Posted 39 minutes ago 1 hour ago, Jothetaxi said: Thanks for the reply. Do you think brick cleaning would help to make it look less obvious? Yes, and re, pointing the original section at the same time the new section is pointed would at least get the pointing to match.
