43 minutes ago, Nickfromwales said:
That projects out almost as much as the previous detail though? Very little in it, from what my Pentium 1 brain is looking at.
To me they're very different, because with my design I have a neat sloped roof panel that's at 42 degrees from the highest point to where it ends, with a gutter concealed in the 42 degrees slope.
With the arch tec's first  draft drawing, the gutter is tacked on to a projection from the roof edge.
So the drawings show this:
1 hour ago, torre said:
Looks like you could vent below your drip into the gutter as the equivalent to over fascia vent if you had a simple gutter fixed outside
Thanks @torre.  I don't follow what you're saying, but your comment makes me think I could have aluminium bits made up to match the roof & conceal the gutter, which would be attached to the plumb cut on the rafter feet & look something like this.
Sorry maybe this is clearer re the vent
I do think your last detail is a decent compromise in terms of the look you want and being constructable. Probably quite a bit wider though to avoid overshooting
Thanks, @torre.  I think attaching my gutter solution to the plumb cut rafter feet will be less costly than cutting all the rafters. I may end up with something like this.
These do look very ‘cool’.
All you need is a bloody good metal roofer who can fab these kind of things in their sleep.
Thanks, @Nickfromwales.  I'll let everyone know how they turn out.  Some time in 2027, I should think.
I'm prepared to put plenty of effort in to getting the gutters right.  I think a lot of otherwise good looking exteriors are spoiled by the gutters & downpipes.  I've got both my downpipes on the ugly side of the house, which can't be seen from the road, due to the orientation of the house & the neighbour's huge hedge.
Good approach, your efforts will reap rewarded.
It's a very tricky detail. You have to balance cleaning with over hang, how you detail out the membrane under the roof cladding, if the gutters are long do you need or not an expansion gutter detail, the fall in the gutter, often over looked! The detail might look good at the gutter high end but what about the low end?
Sometimes if I'm discussing gutters in the North of Scotland, Wales where we get iced snow that can rip pretty much any gutter off, but it does not snow that much often enough to warrant snow guards, we just set the gutters a bit lower, so from time to time the rains running down the roof over shoots. Design is about achieving the best compromise at times.
Thanks for your thoughts on this, @Gus Potter.
Re: gutter fall & high end/low end detail, I’m anticipating giving the gutter a good fall.  The gutter will be behind the aluminium trim, which will be perfectly horizontal.
That’s a good point about snow sliding down the roof ripping the gutter off.  I hadn’t considered that.  What I had considered was polishing the standing seam with ceramic coat, to make it easy to clean & that would definitely increase the chances of a covering of snow sliding off, as a big slab.  We’re going for a black roof, & I can see myself getting my long pole washing device out to clean off any birds’ muck that might appear.
As the roof is standing seam, I don’t think it would be too much of a problem to modify some PV brackets (or buy purpose made brackets) to hold some poles across the bottom of the roof, to make a snow guard.  They could just go on for January/Feb, or perhaps if I make a good job, they could be permanent.  It might be good to incorporate a little Tyrolean design influence.  It’s my favourite part of the world.
I can see gutter cleaning being a real problem on a proper 2 storey house with the type of roof & gutter I’m aiming for.  You wouldn’t want to put a ladder up against the delicate edge trim that hides the gutters.  In my case, the gutters are only at first floor height, so I’ll be able to access them using a step ladder, or better still, I have some of these mobile steps I can use.
She seems way too happy about ladders.
Do you get much snow?
No.  I'm in a low part of Surrey.  I'm going to forget about snow for now, & resume the work on my drawings.  I'm sure I'll be back with another question about my BC/construction drawing amends soon.
