Kevan Marshall Posted 7 hours ago Posted 7 hours ago Hi, I have a friend that mother has Alzheimer’s and needs to go into a home, due to her mother owning her home it needs to go onto the market to fund nursing cost, the sale of house went through but surveyors have picked up on the membrane below roof tiles as it is plastic and through time has started to disintegrate, the sale of house has fell through due to this, is there any way around this without removing the roof tiles which are in really good condition, I know membrane is for condensation but does it need to be there to comply with building regulations? Any help would be greatly appreciated, Kind regards, Kevan.
Crofter Posted 6 hours ago Posted 6 hours ago Just to clarify, is the roof slates or tiles? Regardless of what the final covering is, there should be some form of waterproof material underneath. The exact type depends on how the roof is built. E.g. in Scotland, a slated roof would typically have a bituminous felt on to timber sarking boards. Slates come in varying sizes and shapes so you need this continuous layer of timber to nail in to. In England, you often will have a waterproof membrane which sags slightly between the rafters, and battens over the top to carry the tiles. You can use battens because the tiles are a uniform size. But in general, yes that membrane needs to be there. The tiles or slates themselves will shed most of the water but not 100%. They can get damaged, or in strong winds rain can get forced in to the gaps. Repeated exposure of the roof structure to water will cause serious damage. 1
Kevan Marshall Posted 6 hours ago Author Posted 6 hours ago 25 minutes ago, Crofter said: Just to clarify, is the roof slates or tiles? Regardless of what the final covering is, there should be some form of waterproof material underneath. The exact type depends on how the roof is built. E.g. in Scotland, a slated roof would typically have a bituminous felt on to timber sarking boards. Slates come in varying sizes and shapes so you need this continuous layer of timber to nail in to. In England, you often will have a waterproof membrane which sags slightly between the rafters, and battens over the top to carry the tiles. You can use battens because the tiles are a uniform size. But in general, yes that membrane needs to be there. The tiles or slates themselves will shed most of the water but not 100%. They can get damaged, or in strong winds rain can get forced in to the gaps. Repeated exposure of the roof structure to water will cause serious damage. Thank you Crofter, unfortunately it looks like they are going to have to remove the roof tiles and place new membrane!
Redbeard Posted 4 hours ago Posted 4 hours ago 1 hour ago, Kevan Marshall said: Thank you Crofter, unfortunately it looks like they are going to have to remove the roof tiles and place new membrane! ... or ask agent to contact the would-be buyer and offer a discount that is more than the cost of re-roofing? My roof has no membrane (and, unlike your friend's mother's house, never has had). I won't say it has never leaked, but at 100+ years old it still requires very little routine maintenance. If I came to sell, however, I am sure the survey would point out the lack of sarking as an 'issue'.
