SarahG Posted November 27, 2025 Posted November 27, 2025 Just curious if people who have used Protek for 10 year warranty have had this test done. We didn't get it done as part of our air test, but now Protek are insisting we need one. I don't really understand why as we have all the specs of the extractor fans, which I have shared with the BCO who has already signed off the build as complete. So what is the purpose of this test now at this stage? Just feels like it is money down the drain just to tick someone's box. We don't have MHVR installed.
Bonner Posted November 28, 2025 Posted November 28, 2025 Have you asked them where this requirement is defined? Not in building regulations AFAIK, do they have their own list of tests/certifications required?
SarahG Posted November 28, 2025 Author Posted November 28, 2025 It is listed as one of their required certificates yes. I did ask them ahead of time what was needed, but they said they would just request all required information at completion. It just makes no sense to me, why would I pay some company to come and test all the fans to check they comply with BR when I know the spec of them all which I have sent to BR and they have signed off. So I am testing for something I already know?
ADLIan Posted November 28, 2025 Posted November 28, 2025 Ask them for the exact wording/clause number for this. As we agree there is no commissioning certificate for the use of individual extract fans. There will be Building Reg requirement for extract rates from each 'wet' room but this should be in the spec for the fans
Mr Punter Posted November 28, 2025 Posted November 28, 2025 I have had this done in the past and had it done in conjunction with airtightness tests. The tester did not spend long on this. Here is an example:
SarahG Posted November 28, 2025 Author Posted November 28, 2025 Thanks, yes I have asked the builder who installed to come and test the fans. Then I can put in to a report like this and hopefully that will be ok. I wish I had got it done now as part of air test
Mr Punter Posted November 28, 2025 Posted November 28, 2025 3 hours ago, SarahG said: Thanks, yes I have asked the builder who installed to come and test the fans. Then I can put in to a report like this and hopefully that will be ok. I wish I had got it done now as part of air test As long as the fans have been installed correctly, without excessive ducting, you will be fine. It takes less than a minute per extract. I suspect the cooker hood rates are made up.
SarahG Posted December 1, 2025 Author Posted December 1, 2025 Thanks, yes we did this and they seem ok now. Yes cooker hood spec rate seems a bit far fetched! Now on to the next problem, only two to go before we can get our certificate!
