Lincolnshire Ian Posted 18 hours ago Posted 18 hours ago Hiya I have a chicken and egg conundrum. We have a garage without doors, we want to install the doors, but the garage ceiling will need plasterboarding and plastering before we install the garage door. The garage door is on a six week delivery time. Would I be OK to plasterboard and plaster the ceiling on a garage without the door, and if I did this how long can I leave the garage without a door. Many thanks
Nickfromwales Posted 17 hours ago Posted 17 hours ago Use green moisture boards (unless you need to use pink fire rated?) and only skim it a few days before the door is due?
Lincolnshire Ian Posted 6 hours ago Author Posted 6 hours ago 11 hours ago, Nickfromwales said: Use green moisture boards (unless you need to use pink fire rated?) and only skim it a few days before the door is due? I need to use pink fire rated unfortunately.
Kelvin Posted 5 hours ago Posted 5 hours ago I wouldn’t. I gave some leftover sheets to a friend who stored them in a garage with no door. I told him not to but he reckoned it would be fine as it was just a short time. All ruined.
andyscotland Posted 5 hours ago Posted 5 hours ago If it's on the ceiling and relatively sheltered you might be ok, though I'd leave it as short a time as possible. If you don't need access through the front during that time, could you temporarily board up the opening with some OSB or similar? A couple of sheets would be fairly cheap compared to the cost of redoing the ceiling. If you do need access, maybe you could still put some boarding/protection as a "skirt" across the top section of the opening to prevent wind-driven rain etc from getting to the front edge of the plasterboard.
