MikeSharp01 Posted Sunday at 11:26 Posted Sunday at 11:26 Just plumbing in the heat pump and am trying to keep all pressure drops to a minimum. Here are two possible configurations of one part, assume the plastic segment will be copper, which of them is going to have the lowest pressure drop I wonder and how would I work it out? It is all 28mm pipe.
JohnMo Posted Sunday at 11:50 Posted Sunday at 11:50 You have a dinky heat pump, you could easily pipe in 22mm, so if using 28mm don't loose sleep. The difference in pressure drop is very small.
MikeSharp01 Posted Sunday at 12:05 Author Posted Sunday at 12:05 Yes John and I realise I could simplify further as this image:
ProDave Posted Sunday at 12:39 Posted Sunday at 12:39 With a pipe bender I could do both 45 degrees as two bends in one length of pipe. No joints.
JohnMo Posted Sunday at 13:17 Posted Sunday at 13:17 Or just do Hep2O and don't bother tube bending anything.
MikeSharp01 Posted Sunday at 13:36 Author Posted Sunday at 13:36 45 minutes ago, ProDave said: With a pipe bender I could do both 45 degrees as two bends in one length of pipe. No joints. Bending 28mm pipe sounds like a challenge, I got the swept bends in the images to avoid bending myself. I do have a conduit bending machine but I am not sure I can get a 28mm former for it - I will have a look.
ProDave Posted Sunday at 15:45 Posted Sunday at 15:45 I have 28mm formers for my Hilmor bender. It was originally my dad's. I also have the imperial sized formers for it. I don't have the electrical conduit formers though it is the same bender as electricians use so they are available.
