crispy_wafer Posted November 10, 2025 Posted November 10, 2025 Anybody used a Mira or aqualisa digital control as a bath filler? Positive/Negative thoughts. For me I'm not overly bothered about the smart features, but rather the less cluttered look on and around the bath, which I'm aiming for.
Tetrarch Posted November 10, 2025 Posted November 10, 2025 I was vetoed on these suggestions as a showerhead was a requirement, but if you are going full minimalist... Overflow filler: https://www.heatandplumb.com/acatalog/sagittarius-minimal-centrafill-bath-filler-waste-wa-486-c?msclkid=2fe061b79e891f53b0b108a635d67fc7 Ceiling filler: https://www.amazon.co.uk/Kohler-Laminar-Ceiling-Filler-Polished/dp/B0013423IY Regards Tet
crispy_wafer Posted November 10, 2025 Author Posted November 10, 2025 Thanks for that, I've got an overflow filler and a deck mounted showerhead. My main grumble is trying to reduce the amount of control clutter on the bath edge. Think I'm going to concede on this TBH and just look out for some dainty levers.
deasonuk Posted December 26, 2025 Posted December 26, 2025 Do water pressures differ between what a Waste bath fillers has and normal spouts?
Andehh Posted December 26, 2025 Posted December 26, 2025 I think they do, you lose flow rate I think! I'm not an expert, but you can't beat seperate hot and cold taps on their own, but then have the faffage of adjusting temperature. Fwiw the aqualiser customer support is outstanding.
deasonuk Posted December 30, 2025 Posted December 30, 2025 I went for a fitting/design yesterday and got unsold on using a three way valve for the mains taps if I can. (Im on unvented) Recommendation was down to the Thermostat not giving enough temperature for a bath and the pressure drops. Although the guys a salesman I'm happy to take his advice and have a think about it.
Benpointer Posted December 30, 2025 Posted December 30, 2025 (edited) On 10/11/2025 at 09:10, Tetrarch said: I was vetoed on these suggestions as a showerhead was a requirement, but if you are going full minimalist... [snip] Ceiling filler: https://www.amazon.co.uk/Kohler-Laminar-Ceiling-Filler-Polished/dp/B0013423IY Regards Tet That Kohler filler is listed as £825. £825! for a 0.95" chrome orifice ?! WTAF? How about this for £27? Projects just 22mm from the bath wall. https://www.bathroomrepublic.co.uk/bath-filler-sprung-waste-overflow-and-easy-clean-1.html Edited December 30, 2025 by Benpointer
