Walshie Posted October 30 Posted October 30 Hi, I’m having liquid screed poured next week. Build-up is: Block & beam floor 1200g DPM 150mm insulation 1200g DPM UFH 50mm liquid screed Any thoughts on drying time before it would be safe to lay underlay and an engineered timber floor? Is it worth running a dehumidifier for a few days? Any insight would be really helpful. Thanks, W
Mr Punter Posted October 30 Posted October 30 It depends on temperature, airflow and screed type. Allow 1mm per day as a guide.
Clark Kent Posted October 30 Posted October 30 Sorry can’t comment on drying time but I’d swerve the underlay and bond directly to the screed for heat transfer.
Walshie Posted Wednesday at 16:59 Author Posted Wednesday at 16:59 Hi, That's interesting - I hadn't really considered the heat transfer would be impaired by the underlay?
JohnMo Posted Wednesday at 17:12 Posted Wednesday at 17:12 Underlay will kill UFH performance, it's normal not to float a floor on UFH, it's more normal to bond the floor down.
Thorfun Posted Wednesday at 17:13 Posted Wednesday at 17:13 you can get underlay suitable for ufh and wooden flooring. as above to drying times....is it cemfloor or anhydrate liquid screed? i think 1mm per day is excessive for liquid screed. i know that's the value for dry screeding but i thought liquid was quicker? luckily for us we're really slow at everything and our screed was down for a long time before we covered with tiles and wood! 🤣
Barnboy Posted 18 hours ago Posted 18 hours ago If its an anhydrite screed like ours then 1 day per mm minimum, comission you ufh too and then moisture test. Ours was down fo far longer and I couldn't believe the amount of moisture that still came out of it when I commissioned the ufh, our windows were dripping with condensation, you dried them and they were dripping again before you'd finished each window.
