flanagaj Posted October 18, 2025 Posted October 18, 2025 The electrical kiosk is installed and so to is the kiosk housing the STP control box and compressor. I now need to figure out the best temporary solution for getting power to the static caravan, a couple of sockets and lights in the shed and also power to the STP kiosk. I assume the static caravan will have it's own consumer unit, so is it simply the case of putting a CU in the shed with a 32 amp RCD for the shed sockets, a 16 amp lighting RCD, a 16 amp MCB for the STP feed and a 63amp MCB for the static caravan?
dpmiller Posted October 19, 2025 Posted October 19, 2025 careful... Caravans need careful consideration re. earthing @ProDave?
