NBW Posted October 18 Posted October 18 I have a swimming pool heater and I would like to add solar panels to the pool shed Firstly is this even an option. Secondly is it worth it with the size. Thanks
Mr Punter Posted October 18 Posted October 18 Yes you could probably put 3 PV panels on that. There are DIY kits around.
SteamyTea Posted October 18 Posted October 18 2 hours ago, NBW said: swimming pool heater What sort of heater is it? It is nearly always worth fitting PV as the energy is useful and easy to shift about.
NBW Posted October 18 Author Posted October 18 It's an air source heat pump. 32kw Are there DIY kits which include batteries?
Mr Punter Posted October 18 Posted October 18 You can add batteries but I don't see the point for you. The pool can store a fair amount of energy.
JohnMo Posted October 18 Posted October 18 2 hours ago, NBW said: It's an air source heat pump. 32kw Is it an Olympic sized pool? 3x panels will not touch the sides of 32kW. Which way does the shed roof face if the ridge runs north south you can have panels on both sides of the roof I e and east west array
