8 minutes ago, Mr Punter said:
So the merchant sized sheets single layer?  Epic!
66 sheets of 4.8x2.4m 1 top layer 1 bottom layer.
15 hours ago, flanagaj said:
Reworking the design is simple.  The FFL stays the same, but I just instead work out out the over site depth according to.
hardcore, sand blinding, membrane, concrete, insulation, screed.  No?
My comment was based on your moving from an insulated raft to either an uninsulated one or traditional foundations. If you always were on traditional foundations with the slabs just as a floor surface then sure. Is that the case?
If that is the case, then am I right in thinking that you wouldn't have had a completely flat and open space for the concrete guys to do the slab? ie, they'd have to work in room shaped areas with lots of corners? That's bound to have put them off if so.
I'm not having raft foundations.  Maybe with the sleeper walls, it will be a lot of hassle.
