Lincolnshire Ian Posted October 1, 2025 Posted October 1, 2025 Hi everyone We would like to replicate the test that BC will want when they carry out the final inspection. I have asked them what they expect to see and the best and most detailed answer I could extract was, "a normal water test". I have bought the bung to close the pipe run furthest away from the house, and intend to fill the highest inspection chamber with water and monitor for water loss. Am I doing this right, do I need to block the soil vent pipes as with an air test , what is an "acceptable" water drop? Does anyone know of a simple guide for water testing, or could maybe answer a question above. Many thanks
Bonner Posted October 1, 2025 Posted October 1, 2025 The inspector didn’t show interest in any systems, apart from electrical test certificate. It may be as simple as opening the access chambers and flushing a toilet but I would wait until they ask.
Lincolnshire Ian Posted October 1, 2025 Author Posted October 1, 2025 They will want to see a drains test (already discussed it in the most 9 minutes ago, Bonner said: The inspector didn’t show interest in any systems, apart from electrical test certificate. It may be as simple as opening the access chambers and flushing a toilet but I would wait until they ask. and vague terms) and I'd like to test the system before needing to. If there are any problems better to know sooner rather than later.
Oz07 Posted October 1, 2025 Posted October 1, 2025 Just fill it up then as you say see if water drops. I normally put 1m stubs on pipe and test each run when coming out of ground.
torre Posted October 1, 2025 Posted October 1, 2025 We water tested drains the same as @Oz07 , filling enough so any below ground joints were covered and check the water level after a few hours (no need to block vents). BC were more interested seeing the runs and connections than checking any test but it's well worth testing as expensive to fix later. All our soil stacks are external though, so no worries or testing for internal stacks that'll end up built in and hidden. 1
nod Posted October 1, 2025 Posted October 1, 2025 They hardly ever bother doing pressure test on single builds Make sure you have all you rubber seals on each riser and you will be fine 1
Oz07 Posted October 1, 2025 Posted October 1, 2025 2 hours ago, torre said: We water tested drains the same as @Oz07 , filling enough so any below ground joints were covered and check the water level after a few hours (no need to block vents). BC were more interested seeing the runs and connections than checking any test but it's well worth testing as expensive to fix later. All our soil stacks are external though, so no worries or testing for internal stacks that'll end up built in and hidden. Is there any benefit to internal/external stacks. Assume same temp air inside them so no thermal differences? Just neatness u suppose but square boxing in corner sometimes ruins the room
