flanagaj Posted September 27, 2025 Posted September 27, 2025 I will be fitting the Graf tank next week and am mulling over the best option for the housing the compressor unit and control panel. I know Graf do the green plastic unit, but I was wondering whether a GRP kiosk is a better option as I could glue sound absorbing foam to the inside of the cabinet walls. I don't have time to build a brick unit as I need to get the site ready for our static caravan and I only have two weeks. Graf Housing GRP Kiosk
SteamyTea Posted September 27, 2025 Posted September 27, 2025 I used to make GRP sound absorbing cabinets. Not quite as simple as adding some foam to the inside, but with a bit of time, you will be able to tune the sound of the compressor out. 1
flanagaj Posted September 27, 2025 Author Posted September 27, 2025 1 hour ago, SteamyTea said: but with a bit of time, you will be able to tune the sound of the compressor out. You are talking to someone who suffers with hyper vigilance, so it might take some time 😂
Gus Potter Posted September 27, 2025 Posted September 27, 2025 4 hours ago, flanagaj said: I will be fitting the Graf tank next week and am mulling over the best option for the housing the compressor unit and control panel. I know Graf do the green plastic unit, but I was wondering whether a GRP kiosk is a better option as I could glue sound absorbing foam to the inside of the cabinet walls. I don't have time to build a brick unit as I need to get the site ready for our static caravan and I only have two weeks. Ok the key thing is to get your tank fitted and make sure it does not pop out the gound if you have made a mistake with your ground wate level . Stop poncing about worrying about the sound, you still have a house to build!  I gave you a bit of free heads up advice about your stair.. so the above is another bit!Â
