I'd a 7kw arotherm plus installed beginning of the year. It has the cooling chip which had been working for about 2 months in the summer.
However, for the last month or so, when cooling is run for a while (approx 0.5-1 hour), I lose all water pressure.  See that anti freeze valves are releasing all the water.
When cooling turned off, water pressure has been fine and hot water cycle can run without issue.
Installer changed both valves but still the same.  Vaillant tech/engineer said it's not designed to have the anti freeze for this usecase. They can only recommend I remove the valves and use Glycol for anti freeze instead. My installer has not other suggestions.
Has anyone had similar issue or any other suggestions? TIA
Mine works fine with cooling and anti-freeze valves.  What anti-freeze valves are they? Have they been switched out?
They should only open at 3C +/- 1C. What temperature does your flow temp drop to during cooling?
31 minutes ago, Nickfromwales said:
How cold are you running the cooling?
Mine for reference, same model, hits 4C minimum.    I don't have it set that low, but because it cycles the flow temp drops beyond target temp before compressor turns off. My install has the Caleffi valves.
Edited by Dan F
Run my system without glycol and without anti freeze valves.
Why do you need either? Both are there to protect the heat exchanger in the ASHP casing from freezing. It's a big chunk of metal that will not freeze easily, it's also insulated by the manufacturer and in a casing. It isn't freezing any time soon irrespective of temperature outside.
Are antifreeze valve or glycol used in external oil boilers - no.
Other disadvantage of anti freeze valves. Is they are directly exposed to air, so will activate way before any damage would occur if heating is off. Once activated you have drained out part of the water from your heating system, how do you fix if you are not hands on and your plumber isn't available?
